FXD gauge question
Old Jul 18, 2015 | 08:20 AM
Greezey Rider's Avatar
Greezey Rider
Originally Posted by big ron
You will need an acutronix tbar bracket with that. The tbar bracket mounts to the riser and the gauge mount attaches to the bracket...
When I did mine, I looked at the Accutronix mount...I didn't like the bulkiness of it and I was gonna fabricate something or weld on some bungs.
Then I happened across the bracket that I linked to earlier in this thread....
Compact, lightweight and nearly invisible once it is installed.
Old Jul 18, 2015 | 12:17 PM
_LostSoul_'s Avatar
_LostSoul_
Westcoast TBars sells that bracket now. Also look at LA Choppers for a similar setup, around $50. I have an FXDB tank for sale if you want to move the speedo completely off your bars.
Old Jul 18, 2015 | 12:24 PM
tberg725's Avatar
tberg725
Thanks for all the responses fellas now I'm just trying to find a place that I can order some bars from that ain't gonna take 2-3 weeks min to receive lol was gonna go with west coast but I'm just too impatient for that wait
Old Aug 1, 2015 | 09:05 AM
marcocast's Avatar
marcocast
Contact IB to have your account opened
Looking for a clean setup up to?
I moved mine to the frame.
Some might chime in and say moving the speedo is a safety issue, however I rarely ever look at my speedo. I can usually tell how fast I'm going based on the gear I'm currently I'm and the sound of my pipes 😊
Old Aug 1, 2015 | 11:47 AM
STRES's Avatar
STRES
Default FXD gauge question
You will need an acutronix tbar bracket with that. The tbar bracket mounts to the riser and the gauge mount attaches to the bracket. If you use a combination of risers and bars you can attach the above gauge mount directly to the top plate of the risers. I did not do this because the riser bolts are not offset like the stock risers.
That must be hard to see the speedo with that setup
Cafard
Feb 23, 2018 10:12 PM
wlbowers
Jan 3, 2009 04:55 PM
