Gauges on a 06 Low Rider?
Old Aug 22, 2006 | 01:04 AM
wlbowers's Avatar
wlbowers
Default Gauges on a 06 Low Rider?
Parts are not available yet. Well I have never let that stop me.
Parts needed.
67496-04 Triple 1.5” Gauge Mounting Bracket.
74507-04 1.5” Voltmeter Gauge
74509-04 1.5” Oil Pressure Gauge
74513-04 1.5” Oil Temperature Gauge
1” Copper solder coupling
The mounting bracket is for the XL Custom. It fit my needs just perfect, with a little modification.
First I laid a thick towel across my tank and removed the handlebar clamp and laid the bars on the towel.
The idiot light housing pops out with 4 easy to use clips. The clips stayed with the handlebar clamp. This made the alignment for marking the holes to drill a piece of cake.
I took the gauge bracket and slipped the idiot light lens still in the handlebar clamp into the slot on the bracket. Using a long scribe I marked the holes to be drilled.
Now to keep from marking up the chrome I laid masking tape across both sides. I took two pieces of wood ½” x ¾” x 6” and laid them on the drill press vice. I took a clean rag and laid that across the vice slides. I put the bracket in and clamped it with the wood pieces against the chrome.
I drilled ½” holes because on the back of the handle bar clamp there were ridges around the top bolt holes. These were about 1/16” in height. Once the holes were drilled the bracket slipped over the ridges and laid flush against the handle bar clamp. It would leave half of the thickness of the bracket above the ridges. 1/16”
I knew that the clamp would not tighten to hold the bars so I made a wedge out of the copper coupling. This wedge would sit in the risers to give some meat for the clamp to bite into. The bracket keeps the wedge from shifting around in the riser groove.
To make the bracket sit against the bars, I measured about 1/8” down from the drilled clamp holes and cut off the bottom of the bracket. This left a slight flare that will sit against the bars. I had to file the cut line to fit.
It took 3 hands to get it together and I think that it looks great. The parts guy at the dealer is still shaking his head.
The wiring was a piece of cake. I had some large tubing from another project and used that from the frame to just below the gauges. Then I used individuals to go to the gauges. I used heatshrink tubing to mate the singles to the large.
If the sensor adapter doesn’t let the temp track fast enough, I plan on installing a cooler and at that time will move the sensor to there.
Old Aug 22, 2006 | 01:35 AM
TowJam's Avatar
TowJam
Default RE: Gauges on a 06 Low Rider?
That is sweet!!!!
Old Aug 22, 2006 | 01:53 AM
mud's Avatar
mud
Nice job wl.
Could you post a couple shots of the whole scoot w/ gauges??
mud
Old Aug 22, 2006 | 02:00 AM
wlbowers's Avatar
wlbowers
ORIGINAL: mudpuddle
Nice job wl.
mud
Yea, I'll take some tomorrow.
Old Aug 22, 2006 | 02:12 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Awesome job......looks like it came that way from the factory.
Old Aug 22, 2006 | 10:33 AM
WillieC's Avatar
WillieC
I like it very nice and a job well done !
WillieC
Old Aug 22, 2006 | 10:40 PM
wlbowers's Avatar
wlbowers
Here are some more photo's.
[IMG]local://upfiles/6454/A99F7A09B6764F319275F6EA4A234229.jpg[/IMG]
[IMG]local://upfiles/6454/1557758D6DB046DEA1828B7A2706F32D.jpg[/IMG]
[IMG]local://upfiles/6454/59B618BD00C84BFF9CA5CEAA5BA103FE.jpg[/IMG]
[IMG]local://upfiles/6454/96485BD5623B497088980963B0611C68.jpg[/IMG]
Old Aug 22, 2006 | 11:24 PM
wlbowers's Avatar
wlbowers
Few More
[IMG]local://upfiles/6454/85FCFC8C547A4C0097E8059EB1DA714B.jpg[/IMG]
[IMG]local://upfiles/6454/A75AED7BE119421B940A75B94618E108.jpg[/IMG]
[IMG]local://upfiles/6454/0814501C9954450C8DC93C067BBEF3F7.jpg[/IMG]
Old Jan 3, 2009 | 04:55 PM
rockon's Avatar
rockon
wlbowers, could you post those photos again if you still have them? i'm really curious to see this...does anyone know if it would work on an '08 FXDB?
Cafard
Feb 23, 2018 10:12 PM
Hey Man
Oct 22, 2015 06:13 AM
Mchad
Powdercoat & Paint
Mar 4, 2015 12:26 PM
Eric03
Oct 9, 2009 04:12 PM
devils haircut
Nov 23, 2008 08:02 AM
Slideshow: Harley-Davidson's new RMCR concept revives the caf racer formula with modern hardware-and it may be exactly the reset the company needs.
