Rear wheel question
Old Jul 23, 2015 | 01:13 PM
Nevadone69's Avatar
Nevadone69
Default Rear wheel question
Does anyone know if a 5.5" wheel will fit on my 09 street bob. I know stock is 4.5" and I can make custom spacers if needed just wanted to know if this is possible. I would also be running a 180mm tire if that helps to know. Thanks.
Old Jul 23, 2015 | 02:25 PM
WanaRyd Wheels's Avatar
WanaRyd Wheels
Sponsor
A 18 x 5.5" will work with a 180/55/18 tire with no issues!!
__________________
WanaRyd Motorcycle
1-888-926-2793
Old Jul 23, 2015 | 03:29 PM
Tat2u's Avatar
Tat2u
Yes no worries, run one on my 08 with a 200....
Old Jul 23, 2015 | 10:08 PM
Nevadone69's Avatar
Nevadone69
Cool!! Did you have to make custom spacers? Or is the hub the same size? Just bolt on and go ride?
Old Jul 24, 2015 | 03:20 AM
Tat2u's Avatar
Tat2u
all depends on which wheel you get, some are a direct swap, some people lace their standard hub to the new rim... I had to machine new spacers as the offset on the new hub to rim was different.
You shouldn't have any other concerns as you are going with a 180, if you were fitting a 200 you may need to look at a few clearance issues
Old Jul 24, 2015 | 06:35 AM
Nevadone69's Avatar
Nevadone69
Cool. Thank you
quick66ss
Jan 28, 2017 11:49 PM
justin_ryan
Jul 16, 2015 09:32 PM
SoZoomMe
Jul 4, 2012 10:18 AM
2008 glide
Sep 11, 2011 05:26 PM
hog8461
Jan 29, 2009 08:46 AM
