Basic Throttle Question
Old Aug 5, 2015 | 09:07 AM
HighonHarley's Avatar
HighonHarley
Default Basic Throttle Question
I'm sure this is a common occurrence: I have a S & S Super E carb on my 02 Dyna and the throttle responds well on a roll but if you just give it a quick whack/twist it burps and almost dies. Also I have to leave about an 1/8 of twist play in the cables before the throttle actually hits or it will do it whether I roll it on or whack it.
Old Aug 5, 2015 | 10:14 AM
misfitJason's Avatar
misfitJason
You need to reset the carb settings and start over. The problem lies in your adjustment more than likely
Old Aug 5, 2015 | 11:33 AM
XFXDX's Avatar
XFXDX
Agree. Sounds like it needs a tune.
Old Aug 5, 2015 | 11:58 AM
Lama's Avatar
Lama
It's just your accelerator pump screw adjustment needs to be set. Small screw farthest forward towards the front head pushrod tubes, on the right side throttle shaft as you look at the carb mounted on the bike. Adjust that by blip the throttle until it's a clean blip not a bog or gasp for air.
S&S website has downloads of all their products install instructions, it's clearly explained there.
All Super carbs gasp or stall like that when the accelerator pump squirt is too large or too little.
Shootemdownace
EVO
17
Aug 15, 2012 08:30 PM
freakboy
Ironhead
Jan 3, 2009 12:05 PM
20NightTrain03
Exhaust System Topics
Jan 22, 2008 05:25 PM
khansmith
Sep 15, 2007 03:03 PM
hogmech
Shovelhead
Oct 18, 2006 04:43 AM
