Info Please
Old Aug 22, 2015 | 12:29 PM
blueangel73's Avatar
blueangel73
I would think shorter shocks in the rear on a Breakout would life the bike up, longer ones would lower it.......being a shotail and all.
Old Aug 22, 2015 | 04:40 PM
Pigbacon's Avatar
Pigbacon
Originally Posted by Qdog002
I usually have my SM at home with me but right now it`s at my storage unit. If you don`t get a reply today, I will PM you the specs tonight when I get home.
I would appreciate that Qdog.
I appreciate all your guys assistance, but at this time all I need is the correct level of fluid to put in my tubes.
Thanks
Old Aug 22, 2015 | 09:42 PM
mirrmu's Avatar
mirrmu
2010 FXDWG
3.74inch from top of fork tube (29.4oz)
pump slider 8-10 times
fork fully compressed with spacer and spring removed then measure
i done mine not long ago, I bought a 4lt ATF Castrol i reckon it was just over a litre per tube, so get 3 x litre bottles if using the harley oil (not sure if comes in 4lt)
Old Aug 23, 2015 | 03:58 AM
Pigbacon's Avatar
Pigbacon
Originally Posted by mirrmu
2010 FXDWG
Thanks Mirrmu, exactly what I needed.
Old Aug 23, 2015 | 07:31 AM
RANGER73's Avatar
RANGER73
Sorry, that 11oz. was for the 41mm. Google it.
https://www.hdforums.com/forum/dyna-...-fork-oil.html
Old Aug 23, 2015 | 07:51 AM
Pigbacon's Avatar
Pigbacon
I appreciate your help.
It was actually my fault. I should have specified 49mm.
Old Aug 23, 2015 | 10:19 AM
bl_dg's Avatar
bl_dg
Pigbacon,
Sorry I didn't get back to you sooner. For the 49mm WG tubes, you fill to 5.8" from the top of the tubes. (forks fully compressed) The 26 oz sounds about right. The 2" longer forks that I put on the WG took almost a full quart each.
Old Aug 23, 2015 | 12:19 PM
Pigbacon's Avatar
Pigbacon
Originally Posted by bl_dg
Pigbacon,
It's all good. Just making sure I have enough oil.
Old Aug 28, 2015 | 05:44 PM
Pigbacon's Avatar
Pigbacon
Thanks guys for all your assistance.
Thought I'd give you guys a look at the wide glide fork tubes on my Softail.
Thanks bl_dg for the tubes. They make a vast improvement. No more scraping.
Old Aug 30, 2015 | 10:45 AM
jaxdwg's Avatar
jaxdwg
It does look good
tpapa
Aug 3, 2012 02:28 PM
odd_child4life@hotmail.com
Apr 30, 2012 05:33 PM
Dynarider04
Jul 29, 2010 06:35 AM
eazyride
Feb 18, 2008 10:36 AM
Hamperdiver
Aug 15, 2007 06:18 AM
