Rear wheel bearing replacement
I have no reason to think it needs new wheel bearings other than just preventative maintenance.
Any suggestions for a source of good quality wheel bearings that fit an '09?
The second set of H-D (the first time replacing wheel bearings on the bike) lasted ~12,000 miles.
The All ***** lasted ~11,000 miles.
The Drag Specialties lasted ~9000 miles (though I also have a slight belief that the indie I used didn't remove and/or install the old and new quite correctly, as I watched him he seemed to struggle once in a while and when I finally got the tools to do it myself I don't remember him using certain parts of the same tool).
These last ones I've got are Nachi. I installed them at 71,684 on the odometer and I'm at ~74,800 now. So I can't honestly say if they're holding up or not.
From my experience though, if you can afford it, have them changed at *EVERY* 10,000 miles whether they need it or not.
I thought at first that maybe mine are wearing so quickly (seemingly) because I'm a big man, but all the bikes (except maybe for the Sporty's and the new Street bikes) are made to ride double and hold close to 500 pounds, and seeing I'm slightly more than half that, that can't be the reason. It's a multitude of reasons, like the kinds of roads one rides on (are they bumpy, gravel, lots of potholes you just can't miss no matter how hard you try, etc), even though they're nowadays supposed to be 'sealed' they still are exposed to weather and dusts and stuff.
This is all just my personal experience and opinion, but if you don't want to get stranded on the side of the road because a bearing blew up and didn't stop quickly enough to keep it from warping the rim seat, change them at every 10,000 miles with H-D or something more expensive and stay happy.
$100?? Is that including labor?? The ones I ordered from J&P were $11.99.
If I'm lucky, I'll see a little bit of 'grease leak' from one of the bearings and I'll know that real soon I'd better get my *** to puttin' new bearings in.
If I'm unlucky (it's happened twice to me this way), I'll start to feel something just not right in the way the bike is handling and when I stop to look over the bike, I'll see that a bearing is starting to fall apart and that's it...gotta call a buddy and get him to bring his trailer.
It usually happens too fast to limp anywhere and trying to will screw the rim up, so best to just stop right there and get it towed/trailered to get fixed.
So, to sum up, the original bearings lasted 38,800 miles. Then the replacements lasted to 51,327. Then those lasted to 62,670. Those lasted to 71,684.
If you're paying a hundred bucks for a set of bearings and labor to put them in, you're getting charged at least twice too much! I've not paid more than $55 dollars to have front and rear bearings put in by an indie, that's cost and labor.
@stilup - Thanks for those numbers! After these Nachi's croak on me, I'll be getting those Timken's to see how they do.
Perhaps you might want to consider to check things very closely to see if there is a different problem causing the bearing failure.
Do you do a lot of wheel stands?
