Direct vs Chain Cam??
Chains were installed for noise pollution.....geeze, what a bunch of B.S.
My 2 cents.
I'll take a shot here.Parasitic Loss.Meaning the power the enginetakesto power the chain-driven cams. While @ Daytona, a vendor had twoengine displays - one withgear driven and chain drive. They rigged a hand lever to turn the cams. It took a LOT MORE hand effort to turn the chain-drive cams than the gear-drive cams. Add in more precise cam timing and you have a Marketing Bonanza!!!
Not sure why NHRA Pro StockMotors spin 500 Cu In to 10K RPMsusing Gilmer Belt Driven Cams tho
Maybe cam dynamics / valve-train fluctuaction...But I'm sticking to Parisitic Loss and Marketing...
If and when I do change cams - which is in the works, my choice is gear drive...
ok sounds like a great thing to do gut what does it cost to have it installed for those of us not up to doing it ourselves? May as well ask how big of a deal is it to diy? Thanks
The tools cost about the same as having a dealer do it, around 350$
thedealhere is you could sell the tools when your done and make almost allof it back, ordo your buddies bike for a couple of bills and make youmoney back that way.
Or you could "rent" mine for a fee!
If you are doing High Lift cams you may have to do a small amount of grinding with a die grinder to get some extra clearance, I had to do it on my Dyna, but some bikes have the cranck boss notched from the fatory.
In my middle picture you will see the inside of my engine, the crank boss is the dognut shaped area under the cam bearings, this is where i had to grind two half-moons in it to clear the lobes!
the grinding was very minimal
my guides were showing wear at 2500 miles! these things suck! GD is more noisey but I like the sound!
PS that gizmo on the crank shaft is the S&S anti blow by device, IT WORKS!
[IMG]local://upfiles/22371/8E114CE3FE5E42D3847A2CA915F86A96.jpg[/IMG]
[IMG]local://upfiles/22371/2BA2F0DF91F24622A236EFDB8A0F674A.jpg[/IMG]
[IMG]local://upfiles/22371/96394F14A1F4462A8C278DEE591515FD.jpg[/IMG]
