1999 Dyna Wide Glide D02SEE? D08SEE? code
Old Nov 27, 2020 | 06:51 PM
benscratchin's Avatar
benscratchin
Question 1999 fxdwg
Why should I not go look at this bike and buy it?
https://dallas.craigslist.org/dal/mc...223508731.html
Old Nov 27, 2020 | 08:35 PM
John CC's Avatar
John CC
Wow, talk about a hijacking....
Old Nov 28, 2020 | 03:43 PM
benscratchin
Post
Yup, my fault, shoulda started another thread.
Old Apr 30, 2021 | 02:47 PM
Dave Shih's Avatar
Dave Shih
2nd Gear
Default I have the same exact problem, put new speed sensor , same thing , a couple people said it was a voltage regulator, so I just ordered one, I’ll let u know the out come
Originally Posted by CSLOGAN
I have a 1999 Dyna Wide Glide. Runs perfect. Never had the slightest problem. Yesterday, I noticed the speedometer and odometer shut off, while riding, and the engine light came on. Stopped at a light, everything started workng again, then back off at speed. Bike runs fine, never missed a beat. Have read the threads concerning codes, but can't find anything concerning the D02SEE (last "E" looks like an upside down "F"). Also has a D08SEE. Cleared the codes, all good. My question is: what does the code mean and or pertain too? I know what the D02 and D08 part means, but not the "SEE." Thanks a bunch for any help!
PS- checked all wires and fuse. No problems there that can be seen.
Old Apr 30, 2021 | 02:50 PM
Dave Shih's Avatar
Dave Shih
2nd Gear
Default All my codes were clear except #8 , cleared it & ordered a new regulator The
I realize no one has commented on this thread, but just to update, was dealership, had half the store and technicians looking at bike, took all electrical apart, etc, etc, etc....they were really great. Anyway, problem still exists...speedometer and odometer cutting out after starting. Bike runs fine, no problems. Just took center console loose and checked....all seems well, but i did the redneck wiggle to the wires and connections in hopes it was just something loose from vibration. Will update as I learn more. (so far I have been told it "could be" a voltage regulator, or the speedometer is just old...its original from 1999, never changed. Also, the code reads D08set, though it looks like do8see. It also says "cal09")
so yeah , everything you said is exactly what mines doing
even code #8 , I just ordered a new regulator,! I’ll let u know what happens when I put it in
Old Apr 30, 2021 | 03:02 PM
Dave Shih's Avatar
Dave Shih
2nd Gear
I have the same exact problem speedo mileage works fine when I start it, as soon as I take off mileage goes blank, speedo stops working & check engine light comes on when I come to a stop, everything normal everything works as soon as I take off same problem, so I changed the speed sensor, didn’t fix it checked the codes , everything cleared except #8 cleared it , & a couple people said it was my voltage regulator so I just ordered one, stay tuned I’ll let u know what happens when I put it in
acosta0824
Apr 17, 2017 10:55 AM
controlsct
Jul 18, 2014 12:54 PM
controlsct
Jun 16, 2014 01:27 PM
JR-Boston
Apr 20, 2011 06:19 AM
codyshop
Jul 23, 2009 10:43 PM
