How to tell if clutch needs replacement
Old Sep 19, 2015 | 10:35 PM
archergodwin's Avatar
archergodwin
A good clutch will have no bluing on the steel plates, and the friction plates should measure close to 0.049, and no loose "fibers".
As I said before though, do a full clutch adjustment: loose the cable to put maximum slack in the clutch cable, remove derby cover, loosen jam nut... tighten the center screw to snug, then back off 1/4 to 1/2 turn and tighten jam nut... readjust for proper lever play with the cable adjustment... checking the clutch ramps on the right side, is more in depth, but should not be a factor in 'hot rodding' the bike.
BuckeyeUltra
Aug 16, 2023 10:21 AM
bladeguy
May 20, 2021 09:36 PM
snookedsteve
EVO
Jan 9, 2016 04:38 PM
texacon
Jul 18, 2011 07:32 PM
Pippeis
May 27, 2006 12:36 PM
