cost for stage 1
Old Sep 23, 2005 | 02:44 AM
fordracing19's Avatar
fordracing19
Default cost for stage 1
What should it cost for the s/e slip ons ,air cleaner, and download At the parts counter or ordering online or haveing it installed on the bike? I was at the dealer today and wide glides had dealer installed stage 1 and a wide tire kit installed 180 rear for $945. I would want the stage 1 kit but am capeable to put it on myself if they gouge for install. Freight was $275 and $345 for setup. They sell at msrp.
Old Sep 23, 2005 | 09:47 AM
billnourse's Avatar
billnourse
Default RE: cost for stage 1
About 139.00 for SE aircleaner, around 300.00 for the pipes and I think 189.00 for the re-map for the fuel injection. Labor is probably 4 hours.
Regards,
Bill
Old Sep 23, 2005 | 10:35 AM
sbolt's Avatar
sbolt
I think Bill is spot on for the A/C, I think I paid 229 for the SE slip ons, and I am a carb, so no clue about the remap charge for cost or time. If you are a wrench at all the pipes and A/C should take no more than 1 1/2 hours if you really take your time, it's pretty simple to do
Old Sep 23, 2005 | 10:45 AM
HDF Tech's Avatar
HDF Tech
Do the work yourself and add a TFI, then you don't need the dealer for anything. Spend the $$$ on something else you want.
dragsta's Avatar
dragsta
I recommend NOT getting slip-ons. For and extra C-note you can get some nice pipes. When you remove that crappy stock exhaust system, you will understand.
Old Sep 23, 2005 | 11:03 AM
HDF Tech's Avatar
HDF Tech
There's been quite a few people that have found that the stock head pipes actually work pretty well as compared to other aftermarket systems.
Old Sep 23, 2005 | 05:15 PM
dynamac's Avatar
dynamac
Check out ebay too. I bought the SE Air cleaner and some SE slip ons for under $150 total. Installed it myself, it's pretty simple and straight forward. I have a carb so can't you help with the down load.
Old Sep 23, 2005 | 06:09 PM
dragsta's Avatar
dragsta
Yes, slipons work well but they look only so so and it leaves that hodgepodge of a stock exhaust in place. People only use slipons because they're easy to install. Do it once and do it right.
Old Sep 23, 2005 | 06:58 PM
LouieWideGlide's Avatar
LouieWideGlide
I don't know the price of the slip ons, but the download is $150 + labor. I just had it done on Monday. They only billed me for a half hour of labor. Here in NY, an hour of labor is $90!!!!!!!!!!!!!
Old Sep 23, 2005 | 08:19 PM
dragsta's Avatar
dragsta
This just confirms my, Just Say No To Fuel Injection, stance. Having to rely upon the dealer to remap would **** me right off.
