16"front rim
Old May 6, 2007 | 01:08 PM
dailydriver's Avatar
dailydriver
Default 16"front rim
This has probably been covered already But, has anyone change out there front rim to a 16"x 3.5"...
I want to run big white walls and no front fender and nothing screams bobber like a fat front wheel...
Thanks..Later
Old May 6, 2007 | 01:48 PM
piniongear's Avatar
piniongear
Default RE: 16"front rim
Sure thing.
If you have a wide front end the tire will easily fit. The tire will also fit on a narrowglide front fork but the clearance is closer.
All you need to get is the following:
new set of spokes and nipples.........
http://www.buchananspokes.com/
new rim
new tire and tube
Build your new wheel (or pay someone to do this) using your existing hub, axle, spacers etc.
If you call Buchanan Spokes and tell them what rim and hub you are using they will tell you what length spoke you need as well as the different spoke materials offered. You can buy direct from them using a credit card........pg
El Chiguete
Sep 5, 2016 08:43 PM
Ridgerunnr
Jul 5, 2016 11:09 AM
FXSTC_Bill
Wheels/Tires
May 4, 2013 09:15 PM
GoofySB
May 5, 2012 07:43 PM
IDMT92
Wheels/Tires
Apr 21, 2012 09:24 AM
