Help!!
Old Nov 3, 2015 | 08:29 AM
Odin510's Avatar
Odin510
Default Help!!
I was reinstalling my shift lever on my street bob, and the bolt snapped. You can see the break in the gap between the threaded and unthreaded portions of the bolt hole. I was thinking to drill the bolt with 1/4 in drill bit. Then try and thread tap using 5/16 18 tap. Any suggestions? The lever came back from powder and I think some powder got into the threading.
Old Nov 3, 2015 | 09:28 AM
enodrano's Avatar
enodrano
In the future when you get parts back from powder you may need to ream all non-threaded holes and tap all threaded holes. Sometimes powdercoaters will plug holes prior to powder coating and/or clean up the holes afterwards, but you have to talk to them about it beforehand.
What you need is a bolt extracter like the following:
http://www.autozone.com/test-scan-an...es/246368_0_0/
Old Nov 3, 2015 | 09:35 AM
byrdman.45's Avatar
byrdman.45
I'd use a left handed drill bit and maybe the broken piece will unscrew itself.
Old Nov 3, 2015 | 04:37 PM
stilup's Avatar
stilup
You can drill it with your 1/4 inch drill. maybe enough will drill out just to retap it.
5/16-18 tap drill uses a letter F .256 dia drill. the 1/4 should work for you.
Use a center drill to start central if you can.
Old Nov 3, 2015 | 04:48 PM
ripn's Avatar
ripn
You can also try and heat the area up around the broken bolt until it is super hot, then melt wax onto the broken bolt and hopefully penetrate down the treads . When it cools ( you have to wait until it cools), sometimes the wax will provide just enough of a barrier to help remove it with a LH drill bit or extractor. Used this trick several times on automotive exhaust manifolds and headers w/ success. Good Luck.
Old Nov 3, 2015 | 06:43 PM
Odin510's Avatar
Odin510
The lever was mounted on the shaft, and I couldn't get a drill into the opening. Ended up breaking the lever. I have to cut the remainder off. Anybody sellin one cheap?
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Kinda' defeats the purpose of having the part powder-coated doesn't it?
Old Nov 3, 2015 | 06:47 PM
Odin510's Avatar
Odin510
It sure does! Going forward, I will test any parts BEFORE mounting on the bike. I could simply have ran a thread tap and avoided all of this!
Old Nov 3, 2015 | 08:16 PM
dyna rider's Avatar
dyna rider
Default Shifter Bolts
Those 5/16-18 bolts that come installed from the factory, are grade 8 bolts. They would be hard to drill out.
Old Nov 3, 2015 | 10:55 PM
stilup's Avatar
stilup
http://www.ebay.com/itm/Heim-Joints-...-/391019838066
Modify yours. I did.
