Install T bars on 16' Lowrider
Old Nov 23, 2015 | 11:18 AM
emperor wurm's Avatar
emperor wurm
I have an extended upper brake cable for your bike. Its a magnum shielding, brand new never used, I paid 80, ill sell it for 60. Let me know, Thanks.
Old Dec 21, 2015 | 12:17 AM
1stdynalow's Avatar
1stdynalow
I have the parts on order for my bar job on my 2016 lowrider. I will post pics when everything is up on the bike.
Old Jan 7, 2016 | 12:30 AM
1stdynalow's Avatar
1stdynalow
Default West coast T-bars
That feeling when you call the dealership a few weeks after ordering West coast Mx T-bars and find out it will be around two months wait. 😕
Old Jan 7, 2016 | 02:18 PM
DynaKid94's Avatar
DynaKid94
Check out Lucky Dave's MX style bar - I've got a few buddies that run 'em and swear by them.
http://luckydaves.com/product/the-san-diego-bar/
No waiting 2 months either.
Old May 1, 2016 | 09:13 AM
PacoElProfesor's Avatar
PacoElProfesor
Originally Posted by Lama
Good first post thanks for the detailed breakdown. Now you have seen how dealers RIP YOU OFF.
So how most guys would do it if they wanted to go 12" or 14":
Ebay a used 2006-2015 Street Bob clutch cable $60
Ebay a used bottom mount Dyna headlight bucket and mount. $80
Buy some 12/14 whatever T-Bars, again the Ebay knockoff or some fancy name brand. $200
Dot 4 fluid from Pep Boys or wherever. $5
Drain the trans fluid out into a clean container, then re-use it. Its a HD transmission, not a Bugatti Veyron power steering pump. $0
Trans cover gasket? Re-Use, they are always intact 99.9% of the time. $0
Riser bushings, if you must then yes buy some fancy ones. Not needed really if bike is new. $35
Front Brake lines: Buy individual fittings and lines from JP Cycles or wherever. You will need 3 90* elbows, a brake "T", and three lines. Buy the fittings, mount. Then measure the correct length for the lines, order three correct length braided or black coated lines after you have measured. $140
Black Tyraps $5
= $525.00
It takes all of maybe 3 hours to do the job.
In this scenario, are you using the stock throttle cables?
Old May 11, 2016 | 02:17 PM
comradwes's Avatar
comradwes
Stage I
Default 2016 Lowrider S 12" MX T bars
Got my 16 Lowrider S changing bars here is what's required:
Clutch Cable:
Magnum Shielding Black Pearl Designer Series Standard Length High Efficiency Clutch Cable - 422010HE
Part # 1903449around 80$
Lower Brake Lines:
Magnum Shielding Black Pearl Designer Series ABS Dual Disc Lower Brake Line - AS47006
Part # 1910478 around $199-250
Upper Brake Line:
Magnum Shielding Black Pearl Designer Series 28 in. ABS Front Upper Brake Line for Softails w/7/16 in./90° Banjo - AS47328
Part # 1909673 Around $60
Transmission Cable cover gasket, oil, brake fluid
If you bike is equipped with ABS make sure to get ABS lines!!!
stock wiring is long enough for 12" bars
Old Jun 14, 2016 | 12:04 PM
goofyryder's Avatar
goofyryder
5th Gear
Originally Posted by Mchad
Depends on how tall. I have 8" on mine, I've heard 10" work without extending as well. For the fairing, you'll need a bucket ($60) and a mounting block (~$10) and some misc nuts and bolts. The bucket and the handlebar wires are plug and play. Unless of course you need to extend them...
Took me bout 2 hours to install the bars.
hi I have a 2016 low rider s and my new ape hanger has a 14" rise. I got the extended clutch cable from HD and will handle the wires myself but I can't find the extended ABS break lines anywhere. Actually my experience with this bike as far as parts is concerned has been pretty miserable, people tell you they don't have parts for it (WTH?). Anyway anything helps I know someone must make this I've seen pictures online. Thanks for your help.
Old Oct 24, 2016 | 12:04 PM
mattsw21's Avatar
mattsw21
4th Gear
anybody got a youtube video of the install on the lowrider S of T bars or a good write up ?
Old Oct 24, 2016 | 12:28 PM
goofyryder's Avatar
goofyryder
5th Gear
brother I don't mean to be a dick but I would strongly recommend you paying someone to do it for you. Not only it's got TBW you will also have to bleed your ABS system which as I understand only Harley dealers and big shops has that computer available. For me it's a safety concern. I paid $400 for bar installation and $220 for my local dealer to handle the brakes for me. It's just piece of mind mate. Cheers!
Old Feb 21, 2017 | 10:58 PM
Highwaymans's Avatar
Highwaymans
Definitely not true. Just did 12"risers and 2" rise mx bars. TBW is easier then cables IMO. Plenty of cable all around for even 14" rise. And bled the front brakes with a hand vacuum pump. Seriously not a big deal.
