Throw over saddlebags
Old May 7, 2007 | 07:58 PM
moonsfmc's Avatar
moonsfmc
Default Throw over saddlebags
I was thinking of buying a pair of throw over saddlebags and was wanting to know the risk i would have of ruining my paint or a way to prevent this from happening. thanks
Old May 7, 2007 | 08:15 PM
Splatter's Avatar
Splatter
Default RE: Throw over saddlebags
Risk is about 100% if you're really touchy about paint. Not-so-bad if you're relaxed about what constitutes "ruining." An issue with throw-overs is that if they get out of balance, they'll slide to one side unless restrained. I put a solo rack on the back of my bike, so it was easy for me to zip-tie 'em to the rack so they won't shift. But if you don't have a rack, it adds about $300 to the price of the project.
Old May 7, 2007 | 08:29 PM
Burple_X's Avatar
Burple_X
If you use textile bags, they usually come with a foam type backing which is a little easier on the paint than leather. I use Tour Master textile bags and don't have a problem. Of course I'm not running a solo seat either .
Old May 7, 2007 | 09:36 PM
moonsfmc's Avatar
moonsfmc
Thanks for the help i do have a motherwell solo rack so i guess i could zip tie it to the rack would that work you think?
Old May 7, 2007 | 09:38 PM
Biggol's Avatar
Biggol
Would probably work for you. I didn't think mine would slip or stretch but they did and I have minor pipe burns on one of them now. Going to flip them around and figure out a better way to hang them before I slap them back up there.. Either that or put the heavier stuff on the non-pipe side - hehehe
Old May 7, 2007 | 10:21 PM
SPECIAL ED's Avatar
SPECIAL ED
Well I pretty much ruined the paint on mine with throw overs so let me tell ya what I did wrong and how to not do it.First of all throw overs work great if you have a full two up seat.Just take the seat off lay down a soft piece of cloth over where the yoke of the bags will sit put the bags on and bolt down the seat on top of it and tie off the bags to the shock mounting points with the little leather strings that usually come with it and your done.Of course if you don't have a back seat there will be nothing to hold down the yoke the soft cloth will blow out on the freeway and the combination of wind and vibration will move the bags around enough to ruff up your paint like fine sand paper.Now I didn't have a luggage rack and that may work too but I got frustrated and ended up converting my throw overs to quick detach with Easy Brackets.
Old May 7, 2007 | 10:25 PM
Splatter's Avatar
Splatter
ORIGINAL: moonsfmc
I'm sure that would be fine. I have a set of Wille & Max compact slant bags. (Good fit for the Dyna.) They have D rings at each corner and I just zip-tie 'em to the rack so they can't slide side-to-side. I'm afraid there's not much chance of having mint paint with any throw-over. Dust gets under the band and just normal vibration will cause some light scratching. Again, if you're a fanatic, it's totally unacceptable. If you're more relaxed it's not that bad as long as you take 'em off and clean once in a while.
Are you totally committed to saddle bags? There's a tail bag called "Biker's Friend" that will ride on your solo rack and give you good capacity without scratches. I have one and would recommend it, but it's not as easy to get in and out of as the saddle bags.
Old May 8, 2007 | 12:59 AM
Jehu's Avatar
Jehu
Solo rack -wire (zip) ties!
Old May 8, 2007 | 01:00 AM
BigJfxdwg's Avatar
BigJfxdwg
I second the Biker's Friend. Mine is awesome and give's me a nice back rest. I had thought about throw overs but saddlebag gaurds, and the fact that they alter the look of the bike steered me away, stumbled on the BF and best $$ I've spent so far.
WoodButcher66
2014-2024 Touring Models
19
Jul 16, 2017 11:24 PM
luckycaribou
Dyna Parts
Jun 22, 2014 05:15 AM
2NAHNTR
Jun 27, 2013 12:40 PM
notmyspam32
Jul 25, 2007 12:45 PM
girlierider
Sep 7, 2006 09:47 PM
