HFT lift debate: FXD pespective?
Old Jun 2, 2016 | 10:19 AM
cvaria's Avatar
cvaria
Originally Posted by cggorman
I would eventually upgrade, but right now I can't justify the cost for a proper lift. I just need to be able to get the whole bike off the ground and leveled. Right now all I've got is a glorified center stand.
Similar to this:
It's fine for what I've needed up to now but I can only get one end at a time off the ground
fair enough, here's your guy:
http://www.harborfreight.com/1500-lb...ift-60536.html
use a hft 20-25% coupon
http://www.retailmenot.com/view/harborfreight.com
just search for one when you are ready to buy it.
mods:
Originally Posted by rog246
Do you have pictures of the modifications?
https://www.hdforums.com/forum/sport...today-237.html
the SClonghair mod needs t be called the "dyna horror" mod
https://www.hdforums.com/forum/dyna-...ification.html
Originally Posted by SC-Longhair
I'm not sure if anyone has thought of this but I came up with a solution to a problem that a lot of us have using the Sears red jack to lift our Dynas.
I certainly can't afford to spend $400 or so on a J&S or Pitbull that is built wide enough so the h-d lift adapters aren't necessary.
This technically falls within the 'Under $50' thread and I may post it there also but for now...here it is for your viewing pleasure.
http://www.youtube.com/watch?v=M8lanUaFQNE
Parts / Tools needed: (Added 4/9/2011)
4 - 1/2" x 6" bolts
8 - 1/2" ID fender washers (1 between bolt head and lift pad / 1 between nut and lift pad)
4 - 1/2" nylok nuts
4 - 1/2" ID x 1/2" long spacers *OPTIONAL* / Check clearance
1 - 1/2" metal drill bit
1 - Drill
1 - Hack saw / cut-off wheel / Saw-zall (power tool strongly recommended)
1 - 1/2" wrench (13mm is a good substitute) / or is that 9/16" (14mm as a substitute). My memory is getting worse by the day.
1 - Garbage can to throw away the Dyna Lift Adapters you bought from the MoCo.
1 - Cold beverage of your choice
1 - Good tunes on the radio
I think that covers it.
UPDATE Aug, 2011: Earthquake tested. Earthquake approved. Thanks to 8541hog for the impromptu (5.9 'quake in DC) research.
Old Jun 2, 2016 | 10:31 AM
Reindeer's Avatar
Reindeer
I've got the red Sears jack modified as posted above, works perfect. I can't imagine I'll ever find a reason to upgrade. Bike is super stable, I usually don't even strap it down unless I'm really wrenching on something, and even then I think its overkill, but it certainly doesn't hurt to error on the side of overkill when lifting a bike.
I'm sure a J&S is better, but the modified Sears jack works great for me.
Old Jun 2, 2016 | 10:51 AM
jpace024's Avatar
jpace024
I have one, works fine with lift adaptors from Harley.
Old Jun 2, 2016 | 10:57 AM
F86's Avatar
F86
I would love to have a J&S lift, and I'm sure I will at some point... But when I picked up my current Dyna I already had a Sears yellow lift in the garage, so I got the frame blocks from Harley. They're cheap, I forget exactly but $25 or $30... The bike is very stable on them, although I suspect the lift itself is not nearly as stable as the J&S. I can shake the bike when it's lifted and it does move around, but it's the actual lift pads moving in relation to the base of the lift, not the bike moving on the pads. I always strap it down if it's up for anything that involves actual wrenching and I've never had a problem. The blocks stay on the frame securely... I know, because I once forgot to take them off for several days (while riding)!
Attached Thumbnails HFT lift debate:  FXD pespective?-img_20160517_143556062_hdr.jpg   HFT lift debate:  FXD pespective?-img_20160517_143618504_hdr.jpg
Old Jun 2, 2016 | 11:55 AM
cvaria's Avatar
cvaria
Old Jun 2, 2016 | 12:45 PM
barcoeng's Avatar
barcoeng
Keep an eye on Craigslist. I bought a Sears lift on there, and it only cost me $30! by the condition it was in, the guy must've used it once or twice only. I modified it, and it's been working great!
Similar to this:
Old Jun 3, 2016 | 06:23 AM
1HD1C's Avatar
1HD1C
I did sclonghairs mod to my HF yellow lift and no problems lifting my switchback
EDIT: forgot to add, I don't care what jack/lift you use a correctly positioned strap
is just cheap insurance
Old Jun 3, 2016 | 08:31 AM
NorthWestern's Avatar
NorthWestern
TinCup made me buy J&S
Smittie2121
Nov 30, 2017 09:40 AM
Timo Love
General Topics/Tech Tips
May 27, 2014 11:15 AM
fastbydrmike
Mar 22, 2011 11:40 AM
PKellyMc
Nov 21, 2008 09:22 PM
JerseyDevil
Jun 4, 2008 09:37 AM
