I'm pretty sure the new Ohlins NIX 22 cartridges are going to be available for the 49mm dyna fork. Ohlins specifies the FXDLWG as a fitment model, which is 49mm. But until they actually release them here, your guess is as good as mine.
Depends. If you are an average 185lb rider, maybe. However I am not, and I pulled it out of my FXDLS in favor of Racetech springs for my weight and their emulators (similar to the Ricor). The Racetech stuff blows the HD cartridge away. Probably due mostly to the correct spring rate, but the emulators are excellent too.
I'll eventually go to the Ohlins carts (if they ever arrive, and are as good as we're hoping) though.
I must have missed it, Mchad, I didn't realize you had tried the H-D single cartridge setup. For me, I guess it is down to deciding between the Traxion/Ricor emulator setup (around $350), or wait for the Ohlins to come out (probably will cost $1000+).
I have been manufacturing and valving NIX30mm Ohlins cartridges for around (I can't remember how long) but when they were introduced & I for put them in Dynas with the 49mm forks. These 30mm piston cartridges will well out perform any 20mm, 22mm as well as the Ohlins 25mm fully adjustable cartridges that Ohlins use to make that were replaced by the NIX 30mm. I have them in my own bikes (2 of them) and use them in FLT's as well (one of them).
Benefits of 22mm cartridges (All need to purchase springs separately):
Will be cheaper than the 30mm.
Fork tubes and cartridges need no modifications.
Are full adjustable, compression, rebound, and spring pre-load.
Can be re-Valved by someone who knows what they are doing.
They will be the second best option for Harley's.
Benefits of 30mm cartridges:
Cartridges should cost $300 more (all come without springs & you have to buy them) if all of the rumors are true on base price.
Fork tubes and cartridges need modifications to make them work.
When making the fork tubes without a check valve (that are already in them from HD) I have the ability to make the stroke up to 7" long and with the Ohlins piston and holder design, can change the top out spring length and value. This allows for a very smooth top out stroke going into the dips or pot holes. With this design I can also make the rebound any length I want within reason. There are definitely advantages to having a full, adjustable stroke.
Already have all of the spring rates easily available.
Well, don't know if you actually missed anything. It came stock on my FXDL-S.
No kidding, sounds like the MoCo tried to put some nice parts on those FXDLS's. Now, if that had used American made Timken bearings instead of the garbage I removed on my bike I would be even more impressed.
Howard - I checked out your website - why have one type of cartridge in one fork and another type of cartridge in the other fork? Is that how sport bikes do it? Are you talking about the same cartridges that Ohlins USA is about to release? Your website talks about fork modifications, the Ohlins are not more or less 'drop-in'? What is the price on two cartridges (one bike set), I didn't see that on your website.
