Use your brakes
For an example of 100% weight transfer, think "stoppies". Some Harleys will do them, and some won't. And some depends on how the bike is loaded. So it's really a case-by-case situation.
This has been an entertaining read. I like the ones who list extenuating circumstances, to prove one rule won't always work, as if everybody didn't already know. Like if a seagull craps and it gets in your eye and you can't see so at the last second you grab the front brake only and go over the handlebars into the back of a pick up carrying a cow. You smash face first into the cows ****, get cow shat all over then fall back on the road and the car behind you runs you over cause she was talking on the cell phone and forgot her brakes were bad. Front brakes didn't do any good there.
If that's unavoidable (and sometimes it is, I don't care what anyone says) you need to have an instinctual feel of your bike and know what your braking thresholds are. All of this 80/30, 70%, weight transfer, and everything else goes right out the goddam window. A car, or a kid, or a dog, or whatever jumps out in front of you at 15, or 40, or 80 MPH and you're gonna grab a handful, and hopefully footfull of lever.
I'll go to my grave believing that you should use both brakes all the time. I'll go to my grave believing that ABS is vastly superior to human finger modulation. I'll go to my grave believing that racing or riding dirt bikes helps you learn critical skills.
Whether others agree with me doesn't matter to me at all. If someone thinks they're a better rider than me, cool. If someone asks me for riding advice, cool. If someone offers me tips to try and save my ***, cool. Let's just all ride safe out there...
Statistically, somebody has to crash. All you have to do is make sure it isn't you. In my opinion, nothing is ever accomplished by all this internet hand jobbing. But, that is an opinion and only worth what you paid for it
But I get what you are trying to say! LOL
More learning and training are always good. Or at least as it is quality of course.
Use of either the front or rear brake will transfer weight off the rear wheel, and onto to the front wheel.
This is partly because the center of mass of the motorcycle is well above the tire contact patch, so any acceleration or deceleration force applied through that contact patch will result in a weight shift.
And partly because there is a torque reaction when any kind of rotational force is applied to the wheels (either engine or braking force). Apply a force to the wheel in one direction, and the motorcycle wants to rotate in the opposite direction.
Look it up. The 80-20% ratio is pretty common. This is what they teach you in motorcycle classes.
The "80-20", or 70-30, or whatever number you want to use, is absolutely not always correct. It depends on what kind of bike, and how much effort you're exerting with the two tires. You always want a balanced stop, and the part that inexperienced riders don't understand is that those two numbers are changing during the stop. You start out by exerting strong braking force with both tires, for a split second, and then as the weight transfers to the front tire you begin to dramatically increase the force on the front, but at the same time you must begin to reduce the braking force on the rear, because the amount of downforce on the rear tire is dropping. If you don't reduce the braking force on the rear tire, it will lock as the weight shifts to the front.
Yup, they only engage above 20-25 mph. An interesting detail is that if you only hit the rear brake, and the linked system automatically engages the front, it's only one rotor, the left.
When riding in rain, I'll tend to put the braking force more along the lines of 50/50. There isn't enough tire traction to induce major weight transfer, whereas I might put nearly 100 percent on the front brake in a better traction situation.
