Oh yeah, head work time
Old Jan 22, 2016 | 03:18 PM
  #31
monster715's Avatar
monster715
Robby make sure you torque the heads per cometics instructions if using a mls gasket. After the final torque let it sit a while and go back over the bolts in the proper order and torque and see if the bolts move at all. Repeat until the head bolts don't budge at proper final torque
Old Jan 22, 2016 | 06:15 PM
  #32
jack6hd's Avatar
jack6hd
Building your bike should be as much fun as riding it. You'll have lots of self satisfaction when you fire it up.
Old Jan 22, 2016 | 07:11 PM
  #33
robbyville's Avatar
robbyville
Thanks!
It should be indeed, thank you!
Old Jan 22, 2016 | 09:50 PM
  #34
arkstreetbob's Avatar
arkstreetbob
My heads are at Vee Twin right now getting ported. Cant wait to get them on and dyno done.
Old Jan 22, 2016 | 10:36 PM
  #35
HD Pilot's Avatar
HD Pilot
Originally Posted by adm
On the throttle body question, my head flow numbers are similar to Robby's at about 270 cfm on the intake.
I asked the guy that did my heads to measure the flow of the stock (48mm????) throttle body, and it tops out at about 245 cfm, so there is some restriction from the throttle body now and the heads can flow more air than the heads. How noticeable this would be in real life as opposed to on the flow bench is a different question as there are so many variables.
I am currently thinking about where to go with a new throttle body, what size etc. Currently torn between HPI and the SE 58mm versions - although I think the 58mm one might actually be a bit too big and decrease velocity.
Trying to remember what year bike you have but I think it is pretty new but anyway you probably have the standard Dyna 46 mm throttle body. For a 103" to 107" engine build with headwork I would recommend a HPI 51 mm tb or the SE 50 mm, they will handle your heads no problem but will not be "twitchy" at lower power settings. I bought a used HPI 55mm and got a good deal on it but it is overkill during most normal driving - makes for an overly sensitive throttle response, not bad but not perfect either.
A caveat for this is if you think you might go bigger in the future and need a bigger tb.
Old Jan 23, 2016 | 01:19 AM
  #36
adm's Avatar
adm
Thanks for that. The bike is a '14 103" - and it's the stock TB that the bike came with.
I'll keep an eye out for a deal on a 50 or 51mm TB. If I can get one cheap I'll make the swap, but right now it's not urgent. Reading around, it looks like a 50/51mm TB should flow more air than the heads can accept anyway, so any bigger than that probably isn't optimum anyway.
Old Jan 23, 2016 | 01:55 AM
  #37
adm's Avatar
adm
In fact, with a bit of basic math, given that the 46mm TB can flow 245cfm and has an area of 1662mm2, the 50mm TB should have an area of 1963mm - or 18% more than stock. This should equate to a max flow of 289 cfm. All rough theoretical numbers of course.
So it looks like an ideal match to Robby's (and my) heads.
Robby - where did you find these at $319 - I might spring for one!
Old Jan 23, 2016 | 12:36 PM
  #38
rockmachine93's Avatar
rockmachine93
4th Gear
Adm, who did you get your heads done by? They look great!
Old Jan 23, 2016 | 05:01 PM
  #39
adm's Avatar
adm
They were done by a guy here in the UK who runs an outfit called Fast Lane Head Work. He's a top notch bloke who trained with Joe Mondello in the US. No CNC - all done by hand and all he does is Harley heads.
Here's what he did:
"The stock 2014 heads were received, disassembled, soda blasted and then reassembled and flow tested. The stock guides were removed and all ports were profiled including the short side radii, bowl, guide boss and throat areas. The port entrances were matched to the manifold outlets and the combustion chamber was polished. The intake seats were replaced to allow fitment of larger valves. New manganese bronze valve guides were fitted and a precision valve job performed consisting of five angles on the intakes and three angles and a radius on the exhausts. The stock valves were replaced with high flow forged stainless steel valves – modified 1.94” intakes and 1.61” exhausts. All the seating faces were vacuum tested. The stock valve springs were replaced with high performance beehive springs which were set up to provide 175lbs pressure on the seat and 360lbs at 0.560” peak lift of the Andrews TW57 cam profile. The combustion chambers were machined to 86cc which gives a static compression ratio of 10:1 and a corrected compression ratio of 9.3:1 with 3.91” x 0.030” head gaskets. After final assembly the heads were flow tested with and without the stock throttle body and the results recorded. TDC and valve to piston clearances have been checked."
I even got the bike fired up tonight. It's raining here so no road test yet, but she fired right up and nothing went bang or clank. It sounds MEANER.
The top end was a bit noisy at first but seems to be quieting down after only a couple of minutes of idling. Need to go through my snagging list tomorrow and play with it some more.
I'll probably ride it for a bit once the weather clears up and then go back and re-adjust the pushrods as most of the valve train is brand new and may settle in a little.
Old Jan 23, 2016 | 05:30 PM
  #40
rockmachine93
4th Gear
Hot damn, sounds like you got the works! I'm sure some of that noise will quiet down once it settles in and it gets out of the garage I'm a bit new to headwork specs but aren't 1.94 intake valves a bit big for the stock throttle body? Are you planning on an upgrade soon or will you be keeping the stock on? Cheers to your build!
