Help with emulator set up, too many options!!!
Old Jan 25, 2016 | 02:31 PM
curiousg15's Avatar
curiousg15
6th Gear
Just did the springs and emulators in my 2012 fxdwg. set up for 180lb. spirited cruising. I have a bandit for canyon carving. Installed 1.1 race tech straight rate spring. gold valves with all 4 holes drilled spring set at 1.25 turns. 10wt oil set 140mm from top. stock damper rods drilled as instructions say. it is awsome!! I did tear it down three times to reach this set up. I have Hagon 2810 shocks on the rear 13". for me I dont think a WG can get much better.
Old Jan 25, 2016 | 02:34 PM
curiousg15's Avatar
curiousg15
6th Gear
Also 3/4" preload set with Burley adjustable caps.
Old Jan 25, 2016 | 02:35 PM
Newellhole's Avatar
Newellhole
Thanks for the input! Good info there for sure. This is what I was looking for.
Newellhole
Jun 16, 2015 09:32 AM
Baja38ss
Apr 14, 2014 08:30 AM
SURFOR Chop
Mar 15, 2011 08:20 AM
SC-Longhair
Jul 24, 2010 06:01 PM
SC-Longhair
Oct 14, 2009 07:49 AM
