1993 Evo Dyna frame vs newer TC Dyna frame
Old Jan 27, 2016 | 09:32 AM
El Chiguete's Avatar
El Chiguete
Default 1993 Evo Dyna frame vs newer TC Dyna frame
So what are the differences between a 1993 Evo Dyna frame vs newer TC Dyna frame in terms of one beeing better than the other? Do newer Dyna frames are better just like newer Touring frames are better than older ones or there is no real bennefit between them?
Old Jan 27, 2016 | 10:44 AM
DesertDyna's Avatar
DesertDyna
not sure what you are asking? They are different...not better or worse. One mounts an Evo motor..the other a TwinCam.
Old Jan 27, 2016 | 11:23 AM
El Chiguete
Besides the obvious of different mounts I'm talking about improvements similar to what the newer Touring frames (after '09) have: better handeling, capable of carrying a bigger load, etc.
Old Jan 27, 2016 | 11:30 AM
Greezey Rider's Avatar
Greezey Rider
The newer Dynas ('06+) are heavier, other than that they handle pretty much the same.
I'm not a fan of the 49mm front ends on the later Dynas, I very much prefer the 2000 and later 39mm front ends.
The EVO era Dyna frames were pretty much exactly the same as the early T/C Dynas.
Old Jan 27, 2016 | 12:19 PM
Tommy C's Avatar
Tommy C
Too much unsprung weight with the 49mm or inferior ride quality?
Old Jan 27, 2016 | 01:16 PM
Greezey Rider
Both, in my opinion...that front end is heavy.
Old Jan 28, 2016 | 06:01 AM
Rockabillphil's Avatar
Rockabillphil
The frame and swingarm are stiffer on 2006+ dyna models.
New Frame Designs
All 2006 Dyna frames have been re-engineered to provide a significant improvement in handling plus enhanced styling and rider ergonomics. Each model has new fork rake and triple clamp offset specifications. New stiffer, one-inch diameter front and rear axles and a wider, stiffer swingarm combine to improve high-speed handling.
http://www.roadracingworld.com/news/...model-line-up/
JessCuhh Marie
Apr 18, 2020 07:41 AM
brad75raiders
EVO
Apr 10, 2017 05:34 AM
Sadthorn
Oct 24, 2012 06:34 AM
ezmo
Oct 28, 2011 12:16 AM
donte7430
Aug 26, 2007 01:24 PM
