Throttle won't snap back....help!
Old Feb 8, 2016 | 10:27 PM
RustyCage's Avatar
RustyCage
Originally Posted by 203Cree
So the grip by it's self won't spin easily on the bars? Sand the powder off the bars and try again.
It spins, but not as freely as I would think it would. I kind of want new grips now anyways, so probably going to get a pair tomorrow and do some sanding as well.
Old Feb 9, 2016 | 09:50 AM
ackman1968's Avatar
ackman1968
When I swapped bars on my Road King years ago I had the same issue. I did everything these guys have recommended and nothing worked. I was ready to pitch the bars and go back to stock and that's when the solution (for mine anyway) presented itself.
I had rolled the throttle wide open to show my brother what it was doing and forgot about it. When I loosened the cables it suddenly snapped back to idle. All that time chasing my tail and I had the cables adjusted too tight.
Old Feb 9, 2016 | 12:00 PM
Slvr764's Avatar
Slvr764
ackman beat me to it....check your cables, they're probably too tight.
Old Feb 9, 2016 | 03:00 PM
RustyCage's Avatar
RustyCage
The nuts on the throttle and idle cables are backed off completely, and if I pull on the the throttle cable, it opens and closes like it's supposed to. I bought some new grips earlier today (mainly just because I had an excuse to get new ones) and I'm going to give this another go this evening.
Old Feb 9, 2016 | 03:18 PM
emperor wurm's Avatar
emperor wurm
its your cables, I had the same issue when installing my 16" apes. Move the return cable around a bit, the throttle should snap back like it is supposed to. You can figure out how to adjust (tighten or loosen) the cable from there.
Old Feb 9, 2016 | 06:16 PM
Beaux's Avatar
Beaux
Originally Posted by QC
Sand the bars and spray a little graphite lube in there. Buying new grips should be an absolute last resort.
Since mentioned, I did sand the bars also along with the throttle grip ......
Old Feb 9, 2016 | 07:23 PM
RustyCage's Avatar
RustyCage
Ok, got it all working. Ended up having to sand the throttle side of the handlebars. Works great now. Thanks for the tips!
Old Feb 10, 2016 | 08:10 PM
ackman1968's Avatar
ackman1968
I just sold a set of those bars! They guy that bought them is using them on a 97 Dyna.
Old Feb 10, 2016 | 08:31 PM
skinman13's Avatar
skinman13
if the grip is too tight on the handle bar, just wrap some sandpaper around a round dowel (or the handlebar end) and sand out the inside of the grip until it is loose enough to rotate freely...BTDT...
Old Feb 10, 2016 | 09:23 PM
RustyCage's Avatar
RustyCage
I'm diggin them. Wished I would've switched to drag bars a long time ago.
