Throttle won't snap back....help!
Old Oct 20, 2018 | 02:48 PM
Jeffrey Weber's Avatar
Jeffrey Weber
Stage IV
Default Throttle cable sticking
Originally Posted by RustyCage
Having a bit of trouble here....
Just replaced my bars and I cannot get the throttle to snap back? The cable is fine, snaps back perfect if I tug on it. Once I put the grip back on I cannot get it to work. Didn't have this problem when I changed out handlebars before? You guys think it could be the grip?....they are only a little over a year old - HD Get a Grip - grips. I did notice that it doesn't spin freely on the handlebars? Put it back on the old set and it's about the same amount of friction. Anyways, any tips are greatly appreciated. I went from 14" Apes to 8" Tbars, if it makes a difference. Stock cables.
Thanks
I am having the same issue of 03 wide glide.
I have replaced handlebars and grips a few times.
Not usually a big deal.
I put on a Mikuni carb and replaced both cables lubed them replaced grip. I have made tons of adjustments.
Tried everything short of going to stealership.
Everything is new. I am really aggravated with this.
Simple and can’t seem to get it right no matter what I have tried. No burs on handlebar switch housing is brand new and a I used lube on bar prior to install.
Any advice would be appreciated maybe it’s as simple as me overlooking something but as many times and hours I’ve put on it. I can’t see I’ve done anything wrong.
Old Oct 20, 2018 | 08:13 PM
crusader1xxx's Avatar
crusader1xxx
Jeff did you read through this Thread? The answer is in there...sand the bar or sand the inside of the grip, probably because the bars are just slightly larger diameter due to powder coating or chrome....me I would sand the grip...
Old Jun 10, 2021 | 12:24 PM
SlowNLow's Avatar
SlowNLow
6th Gear
Thanks
I just put new bars on and had a similar start. My new bars had flanges at the end of the bar, and I noticed there was a slight flare in them, bent them in a little with pliers and now perfect.
RomeoTango
2014-2024 Touring Models
21
Jan 26, 2022 05:02 PM
Maxxsmart
Mar 3, 2016 10:05 AM
Sterling Archer
General Topics/Tech Tips
Jun 23, 2015 09:18 AM
Mike650
Aug 18, 2013 07:29 AM
blackknight883
Apr 8, 2013 10:19 AM
