4" risers on street bob?
Old May 13, 2007 | 02:01 PM
bobby5's Avatar
bobby5
Default 4" risers on street bob?
Does anybody have any pics of a street bob with stock bars and 4" risers? Where can i order these risers and i wont have to change out brakes lineds or anything will I? How hard are they to install?
Old May 13, 2007 | 02:23 PM
bobby5's Avatar
bobby5
Default RE: 4" risers on street bob?
also on i wanna keep the stock top peice like where it clams the peice that hasthe harley symbol on it is this possible?
Old May 13, 2007 | 03:27 PM
BeavisRules's Avatar
BeavisRules
I have 4 inch risers on my Bob. You can see them in my photo gallery.
I am not sure where you can buy them because a buddy gave them to me.
You can use the stock cables and everything but the front brake line will be VERY tight.
Good luck.
Old May 13, 2007 | 04:02 PM
sandifer's Avatar
sandifer
3" Dogbone Risers....
[IMG]local://upfiles/25056/CF6EFD8F02454A5DA6BFFE7AB9E51F5C.jpg[/IMG]
[IMG]local://upfiles/25056/75E4E9A2EC87412E8CAFD3A0E1A9F20F.jpg[/IMG]
Old May 13, 2007 | 05:25 PM
BOBBER BLING's Avatar
BOBBER BLING
HI I THINK U WOULD GET AWAY WITH CABLES BUT WILL NEED TO CHANGE FROM BRAKE HYDRAULICS PIPE AS STANDARD ONES SHAPED AND WILL NOT REACH
Old May 13, 2007 | 06:24 PM
eleutheros's Avatar
eleutheros
Mine are on the way this week. I ordered from the dealer, $100.
Old May 13, 2007 | 10:45 PM
CHEESE's Avatar
CHEESE
I have 4"ers on mine. I had to change throttle, idle, and clutch cables. BUT, in the last post like this that I responded to, someone said that they were able to change their risers without changing cables. There was no way I was getting away without changing them, so if I were you I would count on doing it.
Oh yeah, and I had to bend the hard part of the brake line to avoid changing it to a longer one. So if you don't want to bend your brake line, count on changing that too.
Old May 14, 2007 | 12:35 AM
bobby5's Avatar
bobby5
what size are the stock risers?
Old May 14, 2007 | 12:51 AM
sandifer's Avatar
sandifer
I believe they are 2"
ORIGINAL: bobby5
Old May 14, 2007 | 06:08 AM
BACA MICK's Avatar
BACA MICK
ORIGINAL: CHEESE
clutch put on the inside of bars
throtle cables , u need to break the plastic clip under the tank to make it work, this allows the cables to go higher into the tank hullow
i done mine easy, but yes without the top plate they move around to much, ive now put on 16" apes
