What size Torx?
Old Feb 22, 2016 | 09:05 AM
Maxxsmart's Avatar
Maxxsmart
Default What size Torx?
Anyone know what size Torx bit is used for the highlighted fastener? My Torx set only goes to T-40, and its a little small. Probably a T-45 or T-50.
Thanks for the help!
Old Feb 22, 2016 | 09:17 AM
2500hdon37s's Avatar
2500hdon37s
Sounds like you've answered your own question... It's either a T-45 or T-50, buy both and be done with it. You'll use both if you work on the bike any extent more. Also pick up a T-27 if you don't already have one as most sets skip the T-27 and Harley uses that size in a few places.
Old Feb 22, 2016 | 09:21 AM
Maxxsmart's Avatar
Maxxsmart
Thanks... I was thinking of just adding those two to my set. Luckily, my job provided all kinds of odd Torx, and security bits, T-27 included.
Old Feb 22, 2016 | 10:17 AM
skinman13's Avatar
skinman13
I believe it is a T-45, same as the front triple-tree clamp bolts.
My SG had throw-over bags with Krome-Werks chrome saddle bag supports that I didn't want for daily riding so I scored some take-off bolts and nuts to go back original. I didn't like that they were not chrome or stainless and I was having clearance issues on my SG because of my max-wide tire and the nuts on the back side. So I flipped them around and installed a chromed acorn nut with LockTite on the show-side I am so-so on the look but it is cleaner than a dull plated bolt head and there are no more issues with my tire anymore.
My son replaced them on his LR with some aircraft engine stainless steel socket cap screws that have been laying around in my garage for 40 years or so that he polished up the caps to look like chrome...The rear width on his '04 LR is slightly wider than my '01 SG so there are no clearance issues with the same size tire.
Old Feb 22, 2016 | 10:26 AM
perki48's Avatar
perki48
I just walked out to the garage and checked the ones I took out of mine. They are T45.
Old Feb 22, 2016 | 04:01 PM
Maxxsmart's Avatar
Maxxsmart
Thanks for the info, and verifying the bit size.
GBHummer125
Jan 18, 2015 05:19 PM
FL450
Nov 29, 2013 04:44 PM
SgtMic
Apr 16, 2010 09:11 PM
jackinthebox
Jan 10, 2009 04:19 PM
KeithB
Oct 29, 2006 10:30 AM
