CGGorman's 99 Wide Glide build thread
Old May 2, 2017 | 01:16 PM
  #551
multihdrdr's Avatar
multihdrdr
Ok...when I get a mental image of someone named ToffeeBrown, THAT one is not what I'm looking for
..If you know what I mean
Originally Posted by cvaria
ask toffee:
Old May 2, 2017 | 01:18 PM
  #552
cggorman's Avatar
cggorman
ask toffee:
Ah! I knew there had to be a gatekeeper for such things. PM outbound!
Old May 2, 2017 | 01:19 PM
  #553
cggorman's Avatar
cggorman
Old May 2, 2017 | 01:22 PM
  #554
multihdrdr's Avatar
multihdrdr
Nope...
but it does explains things...sometimes those little rascals don't want to be flushed down
Originally Posted by cggorman
Old May 2, 2017 | 01:23 PM
  #555
rydercheers's Avatar
rydercheers
I'm not sure it's actually gonna be a Wide Glide when I'm done. Maybe a Wide Bob? Or a Fat Glide?
I like the Fat Glide myself.
Old May 2, 2017 | 01:43 PM
  #556
Reindeer's Avatar
Reindeer
I'd say it's a "modified Dyna".
Old May 2, 2017 | 03:42 PM
  #557
cggorman's Avatar
cggorman
Playing around with the idea of a Lithium battery to make some extra room under the seat.
The AG-1601 is 480 cca, 16 Ah, & 3.2 lbs (and is intentionally turned sideways in the pic)
The YTX12-16 is 480 cca, 22 Ah, & 3.4 lbs
The stock battery is ~310 cca, ~18 Ah, & ~13.8 lbs
stupid photobucket
Thought others might find the data and size comparo interesting and/or useful.
Old May 4, 2017 | 01:19 PM
  #558
SquishyLowRider's Avatar
SquishyLowRider
I read this entire thread today. I can't believe I've missed it!
Great work and even greater that you are back at it!
Old May 4, 2017 | 01:27 PM
  #559
cggorman's Avatar
cggorman
Thanks! It feels good to be able work with my hands again. A lot of things are awkward or near impossible to do now, but I'm getting stronger and re-learning how to move. My right arm used to be my strong one and now it's much weaker than my left USED to be, so simple things often require a failed attempt and re-think on how to do it. I'm still figuring out the best way to connect air tool couplings. My right arm isn't strong enough in that inward direction. I clamp a lot of things between my knees now. Getting better as I work more, tho.
Old May 4, 2017 | 01:33 PM
  #560
cvaria's Avatar
cvaria
bionic Gorman
