New Motor
Old Mar 27, 2016 | 11:29 PM
MidnitEvil's Avatar
MidnitEvil
Default New Motor
I went to grab my bike and head out for a ride the other day. It had been sitting for a bit and not on a battery tender, so it was cranking for a bit without starting. Luckily, before it did start, I noticed it was pissing oil. Looked like about a half quart ended up on the ground.
I checked for obvious things like a loose drain plug or oil filter, but those are all tight. The leak seems to be at the very front of the motor, maybe on the bottom, or maybe where the oil filter bolts into the block, or maybe both.
Thinking the block may be cracked, but I can't really do much where I store the bike, so for now, I just threw some oil dry on the puddle and left it.
Thinking I might need a new motor. Really just too broke right now to do much about any of it no matter what it is. I guess I'm just kind of ranting/moaning here.
It's a 2002 Wide Glide TC88. Thinking if I do end up having to replace the motor, I should go with a 103 if possible, just because I think it would be about the same cost as replacing it with an 88.
Any suggestions or ideas?
Old Mar 28, 2016 | 12:11 AM
stilup's Avatar
stilup
If that is true and your cases are cracked then I would have them weld repaired before I started forking out the big bucks.
Old Mar 28, 2016 | 12:16 AM
fxdlx's Avatar
fxdlx
You checked your oil filter O ring?
Old Mar 28, 2016 | 12:26 AM
Turbo Turtle's Avatar
Turbo Turtle
I bet the oil filters loose or the filter O ring got twisted upon installation. Suddenly leaking after sitting a while is a bit of a conundrum. Here's hoping it's something simple
BOB
Old Mar 28, 2016 | 07:46 PM
ajk511's Avatar
ajk511
I wouldn't worry too hard yet. I doubt your block cracked while the bike was just sitting there. Most likely the filter wasn't tight and it lessened up. 2nd most likely cause is a gasket that rotted out and just blew when you hit it with pressure. When you get the bike out clean everything off real well and top off the oil. Might be a good idea to have a buddy around so you can get down in front and have them crank it. If there's no abnormal noise then let it crank and run and see if you can spot the leak. On the off chance you do have a cracked block it'll be much more cost effective to have the block welded and then build the **** out of that 88 than it will be to drop a crate 103 in there.
Old Mar 28, 2016 | 11:30 PM
HD Pilot's Avatar
HD Pilot
Find the exact source of the leak before throwing the motor out. Clean it up, put more oil in, sprinkle baby powder all over the suspect area, run motor, locate the problem. Could be as simple as a crank sensor o-ring.
Old Mar 29, 2016 | 02:01 AM
fxrnutt's Avatar
fxrnutt
Sumping?
Old Mar 29, 2016 | 06:22 PM
CJD197's Avatar
CJD197
Tell us honestly...do you really want the case to be cracked so you can upgrade to that 103!?! If so, I really doubt it's cracked. Most likely a simple seal.
Old Apr 1, 2016 | 10:55 AM
MidnitEvil's Avatar
MidnitEvil
Originally Posted by fxrnutt
Sumping?
On a completely unrelated note - Dude! I totally love your bike!
mcgainey_86
Dec 16, 2014 01:21 PM
Hogpro
May 8, 2014 01:08 PM
inspector126
Oil Archive (no new posts)
Jul 12, 2011 09:22 PM
veniculum
Jun 22, 2006 09:21 AM
LordVngr
16
Jan 4, 2005 02:33 PM
