Does high wind hinder engine performance?
Old Mar 30, 2016 | 03:23 AM
joe40x's Avatar
joe40x
Wind turns houses into firewood in a heartbeat.
Wind pushes sailboats around the world.
Effect a Harley? No way!
Wow!
Old Mar 30, 2016 | 11:27 AM
HrdNox's Avatar
HrdNox
Originally Posted by nevil
A good tail wind is always welcome.
It depends...If she's cute i'm all in!
Originally Posted by cvaria
it causes engine to doubt itself and its ability to make you happy . mechanical ed follows... disappointment and shame You got issues bud!
Originally Posted by 103 sedona orange
Engine performance, No. Handling, yes.
Yea,like those guys from the UK that have those HUGE tags its like "left Full Rudder!"
Old Mar 30, 2016 | 03:58 PM
fxdlx's Avatar
fxdlx
Sometimes my lack of social skills surprises even myself. While being a smartalec or wisecracker is sometimes entertaining, seems this forum is best when we're helpful. What is obvious to some may not be to others.
Wind for example. While what martinj and some others said may be normally true, if you were to harness the wind, in a ram air or cold air induction system you could gain some horsepower. Like these guys at sport rider magazine did on a dyno. http://www.sportrider.com/ram-air-test-part-deux
Old Mar 30, 2016 | 06:56 PM
Hippie49's Avatar
Hippie49
It just keeps getting better and better.
Old Mar 30, 2016 | 07:34 PM
lh4x4's Avatar
lh4x4
A couple of weeks back I rode in winds that measured up to 62 mph at the airport. The winds were straight from the west and my route was a north south one. Only crossed the centerline three times in fierce gusts. Good thing I was on lonely roads. Should have taken the trike.
Old Mar 30, 2016 | 09:54 PM
AKFXD's Avatar
AKFXD
Originally Posted by robbyville
Last night riding home from work in a pretty nasty windstorm it seemed like the bike didn't have as much punch as usual. Sure it could have been from cross winds and resistance but it seemed like an engine issue.
Started to wonder if perhaps the turbulance could actually limit the air flow through the air cleaner in some way.
Any thoughts?
I think we need to know the exact angle the wind was hitting the bike, and the humidity and temperature. You just can't calculate the affects wind would have on an engine without knowing the variables.
Old Mar 30, 2016 | 10:05 PM
robbyville's Avatar
robbyville
Lol! I'd tell you but I was too busy clinging on in full pucker mode!
Old Mar 31, 2016 | 06:50 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by fxdlx
Wind for example. While what martinj and some others said may be normally true, if you were to harness the wind, in a ram air or cold air induction system you could gain 20 - 30 horsepower. Like these guys at sport rider magazine did on a dyno. http://www.sportrider.com/ram-air-test-part-deux
Their gains were more along the lines of 7 horsepower, at 150 mph, using induction systems factory-designed for ram-air. Boost generation at much lower speeds is negligible, because the air pressure drops exponentially with a reduction in speed.
Maybe one could get something like one horsepower extra out of a Harley at 100 mph by designing and building a ram-air induction system. Or five, driving at 100 mph into a 50 mph headwind.
More power potential might be realized by tuning the intake manifold lengths (ours are way too short), and that would also have the advantage of being independent of forward speed. It's hard to figure out how to fit really long separate intake manifold runners onto a Harley though, without it looking absurd, or interfering with rider ergonomics. It's also a challenge to fit two separate tubes to the intake ports, with the limited space between the cylinders.
Maybe if one used two front heads, or two rear heads, or flipped one of the heads around backwards....
Old Mar 31, 2016 | 09:18 AM
fxdlx's Avatar
fxdlx
Yer right, i should have read it more carefully. I edited my post.
billbrummett
Milwaukee Eight (M8)
22
Aug 14, 2019 05:29 PM
EasternSP
2014-2024 Touring Models
Jul 20, 2018 01:13 PM
fatrob74
May 7, 2016 02:47 AM
KDH92
Dec 8, 2015 05:26 PM
jammer1
Exhaust System Topics
Jul 26, 2006 11:55 PM
