bad bearings
Old May 15, 2007 | 09:45 PM
tinker1's Avatar
tinker1
Default bad bearings
I have a 2006 wide glide. So far I've had to replace the stearing head bearing (under waranty), and now just had to replace the main shaft bearing, the main shaft seal and shift seal. The tech told me that they have to do this a lot on 06 & 07 dynas....
Old May 16, 2007 | 01:24 AM
blueglide88's Avatar
blueglide88
Default RE: bad bearings
That really sux.
Old May 16, 2007 | 01:27 AM
2002fxdp's Avatar
2002fxdp
i wonder if they have a gounding problem. if the everything is not gounded as it should. the voltage will find its way to ground, often times through bearings. when this happens, obviously there is arcing and will ruin bearings fast.
just a thought
Old May 16, 2007 | 01:36 AM
NiteRider's Avatar
NiteRider
Reason being is what ? Would the 6 spd Gear Box have anything to do with it?
Old May 16, 2007 | 02:00 AM
jandlcars's Avatar
jandlcars
From: NOMAD Milton FL Now Originaly From San Rafael CA
6500 my inner primary berring failed
There was a note in bike folder about having to do that repir at every 15000 mi
Old May 16, 2007 | 02:11 AM
marcss's Avatar
marcss
That sucks! What was happening that tipped you off to the problem, noise?
Old May 16, 2007 | 03:06 PM
tinker1's Avatar
tinker1
I developed a leak coming from somewhere under the primary.. this was the main support bearing and the main shaft seal. If you start hearing grinding noises from your primary, or certainly if you develop a leak, go to the dealer and get it fixed.
Big Sack
EVO
Apr 19, 2019 12:39 PM
Almond farmer
Wheels/Tires
25
Aug 8, 2017 11:51 PM
big- mike
Feb 25, 2017 03:51 PM
mchj74
Jan 17, 2015 08:03 PM
djl
Oct 8, 2012 05:02 PM
