Engine swap 88 to 96
Old Sep 17, 2016 | 08:57 AM
skinman13's Avatar
skinman13
great read! So much experience shared...
I'm more of a, "try it," kind of person and that gets me in over my head sometimes but I learned how to swim a long time ago...
and then there is rule #1...you can always go back the way it was if what you are trying doesn't work. Then you know for sure.
Old Sep 17, 2016 | 09:08 AM
F86's Avatar
F86
Originally Posted by archergodwin
It will be the engine, tranny and swingarm...
If you're wanting some more fun when you twist your wrist, you might do just as well, to put a 95" big bore kit, and a little headwork... will more than keep up with a stock 96.
This is definitely what I would recommend, unless you lucked into the newer engine/tranny for free... My 95" Twin Cam makes over a hundred horsepower...
Old Sep 17, 2016 | 09:55 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by refg3880
nope it cleared just fine, has .040 space
You might want to increase that to 1/8 or larger.. Remember the primary is rubber mounted and the bracket is mounted to the frame. On decel it can rub.
Old Jul 10, 2019 | 05:58 PM
taliesin1999's Avatar
taliesin1999
5th Gear
so you put an 08 street glide 96 inch in a 2005 roadglide im interested how tough it was did you also need the ecm off the 08 motor my 05 roadglide is getting worn out found a complete 08 drivetrain was thinking about this swap
donmecca357
May 4, 2018 12:40 PM
dwolfe56
Engine Mechanical Topics
Feb 29, 2016 04:05 PM
HU112BU
Exhaust System Topics
Jun 16, 2010 09:59 AM
davlyo
Nov 1, 2009 12:17 AM
IceHeritage
Dec 30, 2007 10:38 AM
