"FXDX" build question
Old Apr 27, 2016 | 02:40 AM
VoiceofReason44's Avatar
VoiceofReason44
Default "FXDX" build question
It is unfortunate that the FXDX/FXDXT are no longer in production. If one wants such a machine, you go buy one used, or you pick a Dyna platform and start emptying your wallet. We have seems many fellow forum members here build some very nice dynas to resemble the FXDX/FXDXT is terms of asthetics and performance. I sought to do the same. I own a 2015 FXDL and prior to that, I owned a 2014 FXDB. After being ran over on my streetbob, I wanted to continue to achieve my goal of building a bike as close as possible to the FXDX/FXDXT and at the advice of a few friends, went with the Lowrider. My question is that between the FXDB and FXDL, which one is closer to the FXDX/FXDXT in terms of measurements(rake and trail, ground clearance) and makes for a better platform to build upon. Thank you.
Old Apr 27, 2016 | 06:15 AM
mpescatori's Avatar
mpescatori
You want a Dyna with a 29°rake; Low Riders, Wide Glides and the such have a 31-32°rake, handling is completely different.
Old Apr 27, 2016 | 01:44 PM
fskitch's Avatar
fskitch
street bob=29 degree rake
LR, LRS=30.5 degree rake
WG=34 degree rake
You could swap to Street bob trees fairly easy, fairly cheap if you think 1.5 degree rake makes much difference in handleing. Then you'd have dual front disc like FXDX and same rake.
Old Apr 27, 2016 | 02:24 PM
rydercheers's Avatar
rydercheers
WG=34 degree rake
Is the rake even in the trees? Wouldn't it be in the neck of the frame? I know you can get raked triple trees but I figured they were all different frames. I could have sworn I read in one of these threads there's a guy some where that takes the rake out of the Low Rider frames but I can't remember where it was at. I want to say it was in Cali somewhere.
Old Apr 27, 2016 | 02:35 PM
cggorman's Avatar
cggorman
I believe there are two frames: Wide Glide and everything else. The MoCo does/has used raked trees, in both the positive and negative directions.
On my '99 WG all the rake is in the neck, but not all years are that way.
Old Apr 27, 2016 | 03:01 PM
Kraken's Avatar
Kraken
Factory rake on the FXDX(narrow glide) was 28 degrees. Street bob(mid glide) is 29. On a street bob you can increase the turning ability by keeping front stock rake/tube length and increase the length of the rear shocks to 13.5" and still have good handling. 13.5" rear shocks were the stock length on an FXDX. As for ground clearance, on my FXDB I've personally gone to 13.5" rear shocks with wide glide tubes which are ~2.4" over stock and I haven't really scraped a peg since but it doesn't turn as well. I might choke up on the tubes 1/2" or so to see if I can get it to turn better. You could switch the trees out on your FXDL and get the stock rake of an FXDB.
Old Apr 27, 2016 | 03:13 PM
fxdlx's Avatar
fxdlx
I like the extra Rake on the Lowrider. The The older FXDX frames turned too quick and were more prone to high-speed wobble's. Right now I have one of each, fxdl & fxdx. The main thing is to stiffen up the pathetically soft Harley suspension.
Old Apr 27, 2016 | 03:14 PM
izhd's Avatar
izhd
The dual brake is the only thing left in my FXDB->FXDXT conversion. might not do it because of the cost
So I guess my answer will be FXDL just because of that
Old Apr 27, 2016 | 05:39 PM
VoiceofReason44
Seeing as how I already own the FXDL, any recommendations on how to go about decreasing the rake?
Old Apr 27, 2016 | 05:41 PM
Kraken's Avatar
Kraken
triple trees from an fxdb and keep the same tubes.
TOE_CUTTER
Nov 14, 2017 07:24 AM
MegaFauna
May 2, 2017 09:08 PM
jcmusic
Jun 23, 2014 08:23 PM
dynamiamiflo
Mar 31, 2011 05:12 PM
Swamphunter
Sep 2, 2007 09:18 PM
