back pressure
Steve
L.I. NY
Metric to american and lovin it!!!
Taking the baffles out will make a lot of noise but that's all. Your best bet would be to get a set of slipons and believe me when I say it will run poorly with FI with no baffles. The FI needs some backpressure to run properly.
Steve
KC..
Thanx
I really appreciate the help
PS one thing thats nice living on L.I. no problem with finding a harley dealer theres 5 all within 40 miles of me!
I'm in E. Yaphank NY rite by willam floyd and 495. I have the baffels out now and I do have slip ons (screamin eagles II) on the bike already. I dont have a problem with noise since I only ride for pleasure.
Steve
Steve, Not familiar with that area, I get lost everytime I go to LI
Big place!Trending Topics
thanx for the imput seems this forum is very helpfull
steve
Alright my first post on this forum lets see if I can Get an answer. I recently purchased an 04 super glide fxdi and I was wondering if I take the baffels out of the SE II if the lack of back pressure will damage the motor I know I will need to get it re mapped.
Steve
L.I. NY
[c]In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating. reduction of back pressure can result in a constantly lean-burning engine and as a result burn the exaust valves.
Man that high tech talk will give you a headache. Now the simple version.
The reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Unless the air fuel mixture is adjusted to compensate the engine will burn lean.
This compensation has to be done either manually, carb, or by computer, fuel injected. If the mapped range of the fuel injection can compensate that’s great. If not then the range must be varied by remapping. What remapping does is change the mixture ratio over the rpm range and to re-center the range. To effectively remap a system dyno testing might be necessary.
So can the removal of the baffles damage your engine. Yes! If the engine does not receive the compensated fuel air mixture and it constantly burns lean.
If you remap the system you should not have any problems. You might need to change the air intake to achieve the remapping.[/c]
Lee
