2011 FXDC Easy Brackets help
Old May 8, 2016 | 10:09 AM
raw1986's Avatar
raw1986
Stage III
Default 2011 FXDC Easy Brackets help
I have read through several of the easy bracket discussions but have yet to come across my concern. I relocated the turn signals and now I am trying to install the easy brackets but on the FXDC model the bolt for the turn signal is also the bolt that secures the chrome trim. I intend on just buying a nut and securing the bracket that way but the easy brackets don't attach to the original turn signal hole so ill have to use the hole behind it. Has anyone run into this? I am sorry for being so long winded.
Old May 8, 2016 | 10:21 AM
tnriverluver's Avatar
tnriverluver
I did this on my 2011 FXDC using the Viking Bracket which is basically the same thing. There is a threaded nut built into the fended already. Just screw in the quick detach hardware bolt. Just make sure the bolt is not going to contact the tire. I had to trim my bolts so they would be flush with the nut
Old May 8, 2016 | 04:17 PM
raw1986's Avatar
raw1986
Stage III
The issue I am running into is that the rear bolt hole is not threaded so I guess I'm going to go buy a smaller bolt for the rear where the turn signals were located.
Old May 9, 2016 | 05:44 PM
greatbikegear's Avatar
greatbikegear
This is something that we take care of. You will be provided with a 5/16" bolt and nylon lock nut. Here are the installation instruction: http://www.greatbikegear.com/media/PDF/DNA-L2-INSTR.pdf
Rocketman321
Milwaukee Eight (M8)
18
Apr 29, 2019 03:33 PM
danrad55
Mar 21, 2015 03:49 PM
JHL-ShinySideUp
Jul 23, 2012 07:33 AM
rosshog
Feb 24, 2010 08:47 PM
Blathian
Jun 5, 2009 12:20 AM
