High idle. Can't stop it.
Old Jun 10, 2016 | 01:29 PM
Tat2dale's Avatar
Tat2dale
Is your bike showing any codes through the speedo?
Old Jun 10, 2016 | 11:25 PM
FrankDaTank182's Avatar
FrankDaTank182
It wasn't at first. Once I started cleaning the IAC port it threw a lean and rich code. As well as loss of communication with speedo
Old Jun 11, 2016 | 05:57 AM
1HD1C's Avatar
1HD1C
I cleaned IAC also before taking it in and it didn't throw the code until
the ride to dealership to drop bike off..
IAC I believe falls under emissions warranty also so I wouldn't play with it too much
Old Jun 11, 2016 | 07:39 AM
FrankDaTank182
Yea, got an appointment Tuesday for it. So I quit messing around with it, If they try and give me warrant my BS I will dive head first into it. But if they fix it I'm cool with that, being its the last month of my warranty
Old Jun 11, 2016 | 10:05 AM
cggorman's Avatar
cggorman
I'm not sure what the limits of the Act are, but if they start to give you any hassle try bringing up The Magnusson Moss Warranty Act.
Old Jun 11, 2016 | 10:53 AM
Zerk's Avatar
Zerk
Not a Dyna issue. I have had mine take off 2-3 times in 50k. I have had the stalling problem too. Which I think I keep at bay by cleaning the sensor in the induction module under the air cleaner cover. Cheap thing to do.
Air leaks I would think would force it stay high. Not reset when turning bike off.
Old Jun 11, 2016 | 04:56 PM
FrankDaTank182
New issue started today, Borrowed a friends bike to make my rides today, when I got home started messing with mine again after warm up the idle dropped to almost normal. 1150-1200. Still a little high. If I reeves the engine it would settle down around 1500 then slowly drop. If I racked the throttle back to WOT. It would hesitate and sputter then started throwing a code.
P0108 MAP sensor failed Could my whole problem be a leak on the vacuum line going to the sensor? A small leak would explain the varrying in idle levels. (I'm guessing not 100% sure).
Old Jun 11, 2016 | 10:19 PM
Zerk's Avatar
Zerk
Could it be the MAP sensor failed?
Used to be a $45 dollar part.
ultraclassic53
May 9, 2015 12:39 AM
Killerman#1
Apr 3, 2014 07:50 PM
fiscomi
May 17, 2013 01:39 PM
gtojets
EVO
Feb 28, 2010 08:34 PM
ubreal
Oct 15, 2007 08:27 PM
