HD Quarter Fairing Questions
Old Jun 13, 2016 | 01:15 PM
F86's Avatar
F86
Default HD Quarter Fairing Questions
I've been considering an HD Quarter Fairing, but I've never really looked at one up close in person... I have an HD Super Sport windshield with quick release clamps, but it buffets too much for me (and I've tried moving it up and down to find the best spot). I'm not looking for a ton of protection really, but I think the fairing is nice looking and if it took a little bit of the blast off my body in the 70-80mph range I would be happy. I'm thinking about using one with the Bung King 39mm adapters for the quick release clamps, since I have a set. I like to be able to remove stuff from my bike without leaving hardware, so it's only because of the availability of the Bung King brackets that I'm considering this fairing.
Here are my questions:
Does the glass lens interfere with the headlight distance/pattern in any way?
My headlight is top mounted. Will that work with this fairing, or do I need to mount it differently?
If the headlight can be top mounted, can I retain the stock visor, or will that interfere with the fairing?
My hope is that I can unclamp it and have the bike look the same as it does now. I usually ride without a windshield or fairing, but would use it here and there.
Thanks!
Old Jun 13, 2016 | 01:59 PM
AussieTX's Avatar
AussieTX
Don't know about how your headlight is mounted, but I replaced the lens that came with the fairing for one from cee bailey, the HD one was a very poor fit. In my experience the light beam isn't as wide now, but I overcame that issue by adding a light bar.
Sorry I can't be more help.
Old Jun 13, 2016 | 02:01 PM
WVDevil's Avatar
WVDevil
Mine is on a Sportster but here's the answers for my bike:
No. Not that I can tell.
Top mount is fine, mine is top mounted.
Stock visor is also fine.
Recommend you get Dyna specific answer also. Have no idea about the Bung King parts, I have the HD mounts.
Old Jun 13, 2016 | 02:08 PM
rydercheers's Avatar
rydercheers
The top mounted/visor mounted headlight works just fine with the H-D fairings. No issues at all.
Old Jun 13, 2016 | 02:20 PM
WVDevil's Avatar
WVDevil
You got me wondering if I could use this hardware on my Sportster, hate the HD clamps that stay on the bike. Thanks for the idea!
Old Jun 13, 2016 | 02:36 PM
F86's Avatar
F86
Here's the link: http://www.bungking.com/39mm-quarter-fairing-brackets/
Thanks for your feedback!
Old Jun 13, 2016 | 03:46 PM
WVDevil's Avatar
WVDevil
Already emailed them and got response that it WILL work on Sporty as well as Dyna.
Old Jun 28, 2016 | 05:23 PM
WVDevil's Avatar
WVDevil
OK, got my bracket from Bung King and 4 quick release clamps from HD. Looking at the instructions it seems it requires special hardware too. That, I don't have.
Instructions list a shoulder bolt, 2 Belleville washers, and a cup washer spacer as being needed for each clamp. No part numbers listed.
Anyone know part numbers for these items?
Thanks!
Edit- found it. Part number for whole hardware kit is 58790-04, one kit per clamp of course.
Old Jul 1, 2016 | 09:39 AM
shekmark's Avatar
shekmark
My HD quick release clamps came with all parts needed.
Old Jul 2, 2016 | 07:17 PM
WVDevil's Avatar
WVDevil
Mine were clamps only. I have everything now, just a matter of doing it.
