Dude, where's my accessory power adapter..?!
Old Jul 12, 2016 | 07:02 AM
BenBob's Avatar
BenBob
3rd Gear
Default Dude, where's my accessory power adapter..?!
So, I popped into my local HD dealer and asked for a USB connector for my 2012 Fat Bob.
The guy sells me this:
got home, took the seat of the bike and can't for the life of me find the right connector... can you guys take a look at these and tell me if I have a different connector:
Two of those connectors were unconnected, just in protective *sheaths*. I did unplug the rear lighting connector to get a bit more room for maneuver, if any of you lot spot that!
Old Jul 12, 2016 | 07:14 AM
elPrez's Avatar
elPrez
Look for the battery tender plug. Almost all dealers stick one on new bikes.
Old Jul 12, 2016 | 07:17 AM
203Cree's Avatar
203Cree
Yep. That plugs into a Battery Tender harness. Hope that was cheap, because you can get the same thing from BT for about 11 bucks.
Old Jul 12, 2016 | 07:23 AM
hell hound's Avatar
hell hound
if they did install a battery tender hook up it is more than likely hanging from the bottom of the battery box
Old Jul 12, 2016 | 09:08 AM
harley_jeff's Avatar
harley_jeff
OP - if your bike doesn't have the battery minder pigtail installed on your battery they are like $5 on Amazon or Ebay.
Old Jul 12, 2016 | 09:43 AM
robertomendo's Avatar
robertomendo
My stock 2012 Switchback has the battery tender plug hanging out under the tank just to the rear of the horn.
Old Jul 12, 2016 | 10:04 AM
JohnMn's Avatar
JohnMn
You need to go back,, purchase and install one of these to supply power to the device you bought.;
http://www.harley-davidson.com/store...arging-harness
There are cheaper after market options that are very much the same.
Old Jul 12, 2016 | 10:33 AM
Hellbilly562's Avatar
Hellbilly562
Check the left side cover.......it's in there....at least that's where it is on my wife's bike...
Old Jul 12, 2016 | 10:54 AM
JohnMn's Avatar
JohnMn
Why not start at page 1?
Looking at the battery to see if one is already installed might just work,
Old Jul 12, 2016 | 12:20 PM
Reindeer's Avatar
Reindeer
Yep, pull the battery cover off and see if there's already a harness installed. There will be the main battery cable, and a smaller cable with an eyelet on each terminal if it has one. If not, spend the $9 and buy one.
