Lazarus Project: 2012
You're making some serious headway on your Wide Glide!Phat provides: http://www.phatperformanceparts.com/...ub-crgrips.htm
the EXACT grips i was looking for! i guess hd contracted out for these.
Forum dividends and good folks!
i yanked of the plain caps and put on some ebayed caps...
old school grip-lock glue
the filter was held together by GLUE!!!!!!!!! why would anyone do that?
went to napa and got a tee and a connector.... routed the gas/oils out the back into an optional filter. may order another two side filter... dunno.
moved on, changed tranny and engine oil. looks like the first time either have been changed.
Edit: I should add, I got my under A/C filter from DK Custom; if it's glued together I'm going to be one unhappy camper...
It was a drag specialties breather filter before it suffered its mental breakdown
http://www.cruisercustomizing.com/drag-specialties-replacement-crankcase-breather-filter-harley-davidson-models/part/DS-289073
Air cleaner trim and tranny speed check dipstick.... screw that hex nonsense.
Ordered the slider caps/coveres i used last time and a rear master cylinder rebuild kit. The pedal is sticking.... breaks staying applied, no bueno. Stalled rear brake upgrade i was planning tomorrow.
Wait...
https://www.hdforums.com/forum/dyna-glide-models/555768-rear-brakes-sticking.html ... will try...
Also spoke with the crappy wheel shop, they will have more next week. Wheel and tires will get ordered then.
hung them up... may help with the bleeds, may not... seems to have worked before... no logic to back this up.
.... i don't like but they were factory tuned until abot 25 miles ago.
new plugs and SE wires that where on the old dead dyna for about two weeks...
