Lazarus Project: 2012
Old Sep 13, 2016 | 01:52 PM
  #351
cvaria's Avatar
cvaria
Originally Posted by cggorman
Thrust bearing would replace the big flat washer on that tool. Much less torque required to turn the nut.
Thank you. I'll get on it when the wizars supplys the source.
Just bought the paughco 21×3.50 wheel. Will buy tires in a few.
Old Sep 13, 2016 | 01:55 PM
  #352
cggorman's Avatar
cggorman
Hopefully the Paughco hub is drilled better than the DNA!
Old Sep 13, 2016 | 01:57 PM
  #353
cvaria's Avatar
cvaria
Honestly, i THINK, don't know, the Paughco is a DNA. Can't prove a thing.
Old Sep 13, 2016 | 01:59 PM
  #354
cggorman's Avatar
cggorman
Wouldn't surprise me. Pretty typical for several brands to share a single manufacturing source.
Old Sep 13, 2016 | 02:09 PM
  #355
cvaria's Avatar
cvaria
We'll see in a few days when i destroy some bearings.
Old Sep 13, 2016 | 04:52 PM
  #356
cvaria's Avatar
cvaria
Default .... feels wrong.
The "ebays" were nearly the same quality.
I started with the Tincup part numbers and ended up with this selection:
http://www.harley-davidson.com/store...CatEntryType=2
Went with these (because cheap): 43000026
http://www.harley-davidson.com/store...04-43000026--1
Went to the dealer to pick up, boom. The covers were the same as 43428-09... mysteries.
They need contrast....
Old Sep 13, 2016 | 05:11 PM
  #357
TinCupChalice's Avatar
TinCupChalice
That looks great! You're right, the contrast of the gloss black against the chrome looks good and that new 21×3.50 wheel with dual Big Nessies is going to look fantastic...
Old Sep 13, 2016 | 05:35 PM
  #358
F86's Avatar
F86
Wow, It's really coming together... Looks great!
Old Sep 13, 2016 | 05:55 PM
  #359
cvaria's Avatar
cvaria
Default jack sparrow
Originally Posted by cvaria
Originally Posted by TinCupChalice
180/60B-17 (81H) on the rear and 90/90-21 (54H) front...
used JW as a comp. BB matched the price.
120/70b/-21 and 180/60b-17 ordered.
apologies....
unintentional hijacking of a thread resulted in a miracle price match and tires getting ordered:
https://www.hdforums.com/forum/sport...618-tires.html
Old Sep 14, 2016 | 09:48 PM
  #360
multihdrdr's Avatar
multihdrdr
It might be time for you to get a bearing remover/installer $85 shipped (went up $5)
I can point you to a thrust bearing upgrade for this tool (2 bearings) $15-20
https://www.amazon.com/Pit-Posse-Dav...+posse+bearing
Ego-free zone
Thrust beearing? I'm still green. What is that?
Pointing...
Motion Industries Inc (Bearing Supply)
1/2" ID (.500) Bearing
3/4" ID (.750) Bearing
I have a local Motion Industries so i didn't pay freight. I see they have a $9.98 Flat rate charge.
May also want/need to pick up a Thinner 3/4-16 "Jam" Nut (because of adding thrust bearing thickness). I just milled mine, but they are available at a Hardware store.
Goes Here...
FYI, you can pretty much disregard the "Instructions" that come with that tool. Some of it is wrong (unless they corrected it) and other parts have you jumping through unnecessary hoops that make it harder to use.
I can give you some tips later that work for me, especially on bearing installation...a little "out of the box"
Also keep in mind you can use this tool without the "upgrade"
