Lazarus Project: 2012
F86, there was OIL!!!! lots of it... kitty litter had to be unleashed. pretty funny. no biggie. the tarp is there just for stuff like that
laziness tool....
The outer and inner shoes looked ok for ~12k miles
unleashed the goods... to be with the kitty litter.
tested cam lobes for contact/clearance. found contact/clearance.
dentist drill and magnetic suction... suction failed but, it seemed like a good idea.
clearanced.
good, good. blew out all i could with compressed air and then rinsed as best i could.
pulled old bearings. cheated with a 5/8 socket and a power drill.
installed the new bearings
fiddled with oil pump
installed and checked, good
blah
mounted cams and tensioner
installed
test for .10 clearance with stock rear cam spacer. needed .010 thicker .140 spacer over the .130 stock. feeler gauge was happy with the spacer.
that clip was closed and there was blood spilled on the happy rear sprocket
playdoh approved and buttoned up
lifters
scrubby scrubby
blah...
done for the day.
