Lazarus Project: 2012
Old May 28, 2017 | 05:29 PM
  #811
F86's Avatar
F86
Originally Posted by cvaria
tested cam lobes for contact/clearance. found contact/clearance.
clearanced.
After clearancing, did you have the full .030 all around that S&S specifies? Mine didn't interfere anywhere, but I couldn't get an .030 feeler gauge in the bottom against the crank race, or at the top against the inner lifter races. I just did some machining, but after cleaning everything and trying the cams again, I still don't quite have .030 everywhere (close). I'm debating cutting more or not right now... I've discovered something: I really hate machining the inside of an assembled engine! I find it really nerve wracking... It took a long time to mask everything well, and then to clean it out... I guess I'll do it again just to be safe. But I wish I didn't have to.
Old May 28, 2017 | 05:37 PM
  #812
Reindeer's Avatar
Reindeer
Interestingly, I didn't have to do any machining to mine with the 585 cams. To be honest, I didn't check how much clearance I had with a feeler gauge, I just stuck a cam in and I had what I felt was enough clearance that I didn't need to worry about it.
Old May 28, 2017 | 05:51 PM
  #813
F86's Avatar
F86
I almost wish I hadn't measured! I'd be on to the next thing by now!
Like an idiot, I forgot to check until after I had changed the inner bearings (cvaria: 1; Me: 0), so I'm masking things really carefully inside. I hate when I do stupid stuff like that.
Old May 28, 2017 | 06:07 PM
  #814
cvaria's Avatar
cvaria
i did, and i went overboard. my cam intake lobes were hanging up on the
rising material of crankshaft boss. i went beyond .030 even thought it was just the material behind the lobe.
initial marks. i just kept spinning the cams to let them mark up the problems... then i gouged them
i'm sure if there's an issue, it will "auto-clearance". i think you are probably fine. i remember reading that these things are snowflakes and vary in form from bike to bike.
Old May 28, 2017 | 06:13 PM
  #815
F86's Avatar
F86
"Auto Clearance"
When hardened steel meets aluminum... I like that!
But I think I'll go out and remask, then take a little bit more out... It's tightest up top right now.
Old May 29, 2017 | 12:50 AM
  #816
cvaria's Avatar
cvaria
Welp, it begins... because it doesn't start.
cranks but, no go. Maybe i messed up with the push rod shenanigans. Will step back for a minute before trying to fix anything. Will use the the noodle instead of the wrench..
bike is now on the tender recharging.
Old May 29, 2017 | 07:16 AM
  #817
cvaria's Avatar
cvaria
i put the old tune back on it and put it on the battery tender to let it sit over night. it was rough but, it started up in the most fantastic explosion of 110ness.
1 minute heat cycle done. 4 more to go!
Old May 29, 2017 | 07:23 AM
  #818
TinCupChalice's Avatar
TinCupChalice
Fantastic!!!
So much awesome in this thread! Between you, F86, and Reindeer I've got the itch to do my heart transplant earlier than I'd planned.
Video man, post it. I know you've got the skillz
Old May 29, 2017 | 07:30 AM
  #819
cvaria's Avatar
cvaria
Originally Posted by TinCupChalice
Fantastic!!!
yes sir, will do.
Old May 29, 2017 | 08:50 AM
  #820
ROCKOUT Rocker Products
Sponsor
Great to hear!
__________________
NO, they DON'T all do that!
Also on amazon.com...
