Lazarus Project: 2012
Old May 30, 2017 | 06:06 AM
  #841
TinCupChalice's Avatar
TinCupChalice
Originally Posted by W.Glide
Glad to see you got it going! I'll bet it's a torque beast, and will set your azz back!
2 things, in your last video it's idling WAY to slow. You need it idling real close to 1K or you'll starve it for oil. You can get by with 950^, but your way lower than that. That will probably solve your stalling issues as well. The other thing is when you made your map 10% richer, you probably went to rich. Try like 3% and see what it does. When you go to rich it will make the idle rougher, and you'll suck to much fuel. When you can get it dyno tuned, and if the tuner is good you'll love the results.
Just to add to your comment on oil pressure and idle, while I've only got a 'puny' 103" I do have an oil pressure gauge and have experimented with different idle RPM's via the Power Vision. At a -100 you won't have a reduction in idle oil pressure; at a -150 you will begin to see a drop in idle pressure, and at a -200 the pressure was so low it didn't move the gauge needle.
My idle is at 850 - 950 RPM and the idle oil pressure is the same as the stock 950 - 1050 RPM and based on what I've observed I don't recommend people lower their idle more than a -100. Battery charging voltage is a solid 14.40v - 14.50v at a -100 idle, as well...
Old May 30, 2017 | 08:07 AM
  #842
mattVA's Avatar
mattVA
Completely missed this latest engine update. Nice work.
Old May 30, 2017 | 09:55 AM
  #843
cvaria's Avatar
cvaria
hey, i meant to ask you what s&s did for you when your cylinders went out of round. Did they make you whole or brush it off as your fault?
Old May 30, 2017 | 10:55 AM
  #844
mattVA's Avatar
mattVA
I couldn't fairly say whether it was on them so I didn't reach out to them.
Old May 30, 2017 | 07:27 PM
  #845
cvaria's Avatar
cvaria
Made suggested changes and took it out and did another 50 or so....
No problems during the first 30 or so. I even tried to make it fail... nothing. Thump thump thump.
there was funny business later in the ride again. Cane out of the back roads to an intersection and dropped to first and the rpms fell off a cliff... bike shut off. Pulled the hold the throttle nonsense again and went on my way. Tested the rpm drop while rolling. .. if i pulled in the clutch, engine would die. This continued for duration. ..until i pulled into the driveway. .. bike stayed on... wtf?
bright side... S&S was pleased with my stupidity:
View this post on Instagram
Old May 31, 2017 | 03:07 PM
  #846
cvaria's Avatar
cvaria
went back to the 103 tune and did 100 auto-tune miles... no shutting off. bike is stable. swung by the dealer and negotiated a sweet deal for both bikes to get dyno'd. then hopped on my sportster for 2 hours... good day off
Old May 31, 2017 | 04:43 PM
  #847
Reindeer's Avatar
Reindeer
I saw that. I managed to get S&S to comment on one of my pictures, but you got next level bonus points.
Old Jun 1, 2017 | 08:42 AM
  #848
cvaria's Avatar
cvaria
The engine temp sensor situation seems to be under control, for now.
After the first CEL related to the engine temp sensor after the 110 went on, i pulled the terminals and sprayed both sides with electrical contact cleaner then some dielectric grease. Not a peep out of the CEL since.
we'll see how long this goes.....
Old Jun 1, 2017 | 02:29 PM
  #849
cvaria's Avatar
cvaria
Bump accessories coverage to $10k. Not taking that hit again.
Old Jun 1, 2017 | 02:34 PM
  #850
cggorman's Avatar
cggorman
Good idea! I need to check on that myself. Out of curiosity, how does that affect your premium?
