Vance n Hines big shots question.
Old Jul 19, 2016 | 09:18 PM
Bennyg33's Avatar
Bennyg33
Default Vance n Hines big shots question.
I found a set of Vance an Hines big shots exhaust for a steal at $50 like new. He said he thinks there off a 2007 Dyna but they have no 02 sensor bugs. I have a power command 5 so I could just tuck and hide my sensors correct? Would the exhaust have the holes for the 02 sensors if they were for a 2007? I though all for bikes after 2003 did? Any help would be great. Thank you!
Old Jul 20, 2016 | 12:52 AM
JohnMn's Avatar
JohnMn
I'm running Big Shots on my 09 FXD and PC5.
They do have bungs for the O2's and I would think they should for the 07 also,, better double check fit, or work a deal with the guy to get payed only if the pipes do fit.
You can run without the O2's (I am) but there's a plug-in device for the wire circuit called "O2 Optimizers" that are needed to run proper. If your using these then Yes, just tuck the wires away.
Old Jul 20, 2016 | 10:24 AM
Bennyg33's Avatar
Bennyg33
The ones he's selling for $50 do NOT have bungs. Do you think they are not for a 07 FXDB?
Old Jul 20, 2016 | 12:15 PM
nevil's Avatar
nevil
They are not for an 07 anything. Every bike that year had O2 sensors. That doesn't mean they won't fit. Depending on what the pipes were from, they might bolt right up or take a little fabbing.
Like John said, just get the O2 eliminators so your PC works like it should.
11'heritage
Mar 6, 2014 07:51 PM
SuperFastGlide
Oct 6, 2013 02:36 PM
F22 Junky
Jul 14, 2012 08:07 PM
mplecha
Apr 6, 2009 07:22 AM
dfiredog
Nov 13, 2007 03:25 PM
