High/Low voltage codes
Old Jul 31, 2016 | 09:21 AM
Rounder70's Avatar
Rounder70
4th Gear
Default High/Low voltage codes
My brothers 10' super glide is throwing voltage codes. Sometimes low sometimes high. we have changed the battery and the voltage regulator. Anyone ever have an issue like this or have any idea what may be causing it. Any ideas would be greatly appreciated. Thanks
Old Jul 31, 2016 | 02:57 PM
CJD197's Avatar
CJD197
I'd start with grounds. The voltage regulator is grounded to the frame using it's mounting bolts. The pad on which it mounts can get corroded since it is in the splash zone of the front wheel. The next major ground is on the frame under the front of the seat.
A faulty ground can confuse the voltage regulator and computer.
Old Jul 31, 2016 | 03:00 PM
Max Headflow's Avatar
Max Headflow
Check the wires/ connections that connect the regulator to the battery and grounds to both the regulator and battery.. This includes connection to the maxi-fuse and where the wire from regulator connects to the the main cable that goes from the Maxi fuse to the fuse block. I'd check the connection on the maxi fuse also... Also check grounds between the motor / frame / battery / regulator.
Old Jul 31, 2016 | 09:18 PM
Rounder70's Avatar
Rounder70
4th Gear
Thanks for the advise. will check it out. hopefully this will fix the problem
kevjo
Sep 10, 2018 06:51 PM
WildCherry
Aug 14, 2017 02:41 PM
fiddledicksr
13
Oct 9, 2012 12:44 AM
onaride63
Jun 18, 2011 09:50 AM
WRAITH
Nov 22, 2010 01:04 PM
