Exhausts choice for my Dyna, please help!!!
Old Aug 8, 2016 | 10:05 PM
sharkey's Avatar
sharkey
Originally Posted by Maxxsmart
That pipe is a beast... I like it! What tank badges are you running there?
110 Anniversary badges with the top banner removed...
Attached Thumbnails Exhausts choice for my Dyna, please help!!!-anniversary-badge.jpg
Old Aug 9, 2016 | 05:55 AM
XcellMusic's Avatar
XcellMusic
Originally Posted by target64
I hope you realized that the intake closing is 45* on the 574 cam with out the compression addressed that is going to be very sluggish in the lower power band.
Can you give me a little more explaination please? I'm a little lost. Not sure I get it, I'm just starting getting into the technical aspect of the mechanic. Thank you very much
Old Aug 9, 2016 | 04:55 PM
shekmark's Avatar
shekmark
I love my FM 2-1 . Used Woods 222 cam and power vision. Sweet!
Old Aug 9, 2016 | 06:22 PM
target64's Avatar
target64
on your stock 96 cid engine the intake valve closes at 30* ABDC (after bottom dead center on the compression stroke) giving you a corrected compression of 8.98:1 @ 184 cranking compression you want to try and stay with a cam that stays close to that intake closing for the engine to run optimum. or you will have to add a thinner head gasket and machine the thickness off the deck surface of the heads to achieve the proper corrected compression were the cam you chose runs correct. with the 574 cam the intake closing is 45* ABDC it drops your cranking compression to 171 and set your corrected compression too 8.46:1 which is less than you have now and will make the engine more sluggish in the lower rpm's. With that cam its needs the static compression set to 10.3-10.5:1 is were it will run the best. just trying to help you been there added a cam with a later closing and had to fix the problem
Old Aug 9, 2016 | 09:42 PM
XcellMusic's Avatar
XcellMusic
Thanks a lot for the explanations, it is really helpful.
I am going to upgrade to the 107 S&S bolt in kit very soon which I believe will be closer to the ideal static compression you were talking about?
Old Aug 15, 2016 | 05:10 PM
MagnaFlow's Avatar
MagnaFlow
Former Sponsor
Xcell, not sure if you have checked out our 2-1 system, but the Riot pipe seems to fit the style you are going for, and has been one of our top sellers! We'd be happy to answer any questions you might have, so please dont hesitate to contact us!
http://www.magnaflow.com/products?pa...&platform=Dyna
Old Aug 15, 2016 | 06:55 PM
jack6hd's Avatar
jack6hd
Check out Patriot Defender. Good price and good quality.
Old Aug 15, 2016 | 08:45 PM
grouchy's Avatar
grouchy
Default best pipe
I have a 2014 Low Rider with a HD Stage 5 Tire shredder 110 Race kit installed, used a Bassani Stainless 2 into 1 Road Rage III exhaust, fits great, look good, not overly long and sounds and performs great, very happy. Price was good compared to other options. I made a larger heat shield from 304 stainless to stop boot melt.
Old Aug 16, 2016 | 01:47 AM
XcellMusic's Avatar
XcellMusic
Interesting, they are really different looking, which I like but I'd love to have feedbacks on performances compared to the ones that I have on sight.
Old Aug 16, 2016 | 12:33 PM
NO_SPRK's Avatar
NO_SPRK
i was interested till i saw you have to manually set it quiet or loud with tools.
