speed wobbles
Old Oct 8, 2016 | 10:51 PM
  #31
chriswillrise's Avatar
chriswillrise
Originally Posted by JaronB
If you just got a new tire what kind did you get and is it a radial? I just went to an Avon Storm 3D. I went a tire size wider to learn that I now have a wobble. I should have just stuck to Avons recommendation especially with radials. The Max weight for this tire is 805 lbs, but the one Avon recommends for the factory size is 963. I didn't pay attention to the load rating and just assumed the weight was good enough. I've had a shitty radial on the rear before and had the wobbles. Went back to the stock Bias rear and it went away. Trying to find the right radial sucks ***. Next ride season I'll buy the recommended rear radial from Avon and just deal with this one the rest of the season because winter is not far away. Put the rear tire at max pressure and see if it makes a difference. If it does it's probably the tire, so double check the load rating on that new tire.
it was happening before my new tire. New tire is a pirelli mt66
thoner7
Jun 28, 2019 12:24 PM
HarDlife
EVO
19
Jul 11, 2015 10:52 PM
vulhalla
Aug 26, 2007 10:19 PM
arachman
Sep 4, 2006 06:17 PM
ROLAND FLAGG
May 19, 2005 12:33 PM
