Upper Tree
Old Oct 7, 2016 | 09:44 AM
jqb12's Avatar
jqb12
Default Upper Tree
Once the round chrome steering stem cap is unscrewed, and I undo the 1.5 inch steering stem nut, will the upper tree just"lift off" (of course the pinch bolts loosened also)? I'm going to replace the integrated riser upper tree from my 2012 with a top from an 06.
Thanks, Jeff
Old Oct 7, 2016 | 01:07 PM
hsr's Avatar
hsr
Jeff,
Yes. Below the upper tree there is another nut with a serrated looking outer diameter that will still be holding the lower tree in the neck. I did the same earlier this year, but had the entire front end off.
Old Oct 7, 2016 | 06:20 PM
jqb12's Avatar
jqb12
Thank you for responding
Old Oct 15, 2016 | 10:02 AM
archergodwin's Avatar
archergodwin
That serrated nut is how you adjust your 'fall away' of your front tire...make sure you get that set back before riding.
rleedeuce
Oct 4, 2012 06:38 PM
p51bombay
Mar 20, 2011 09:50 AM
icecaps
Mar 12, 2009 06:04 PM
jsbridgew
Dec 26, 2007 06:15 PM
speed8988
Jan 18, 2007 06:38 PM
