IMO I like the Sputhe better than the Predator if you are talking chassis stabilizers. I've not found steering stabilizers to work well on the street.. Might be good if they added a steering speed wobble sensor and made the damping programmable. Daughter has a Scotts that works excellent in the sand on CRF250X.. I've only tried conventional dampers (PMFR) on street bikes. No luck with the wobble.
Like all the guys have said in the many threads in this brilliant forum, check the motor mounts and fall away, and when that is good, then spend the most useful cash ever, get either Sputhe or True track on the ride and it is the only way to lock the Dyna solid like the Softails and fatboys, we can talk till the cows come home but it really is the only rock solid solution, just google Eric Buell patent for rubber mounted bikes, and it will become very clear as to why we need 3 stabilisers like on the Sportsters, the old FXR had 2 and they where awesome, then harley dropped the Dyna range to just 1 under the tank and this is when forums started talking of death wobble, same on the cruisers.
Sputh is the way to go. Had it on my 05 and it was night and day difference.
Must agree with Twistedturbo Sputhe or Truetrack and it really is night and day, however front True track is a 10 minute job, but the rear is a pain in the but unless you remove the rear wheel, I took rear wheel off and it made life a lot easier, give yourself at least 2 hours to install the rear, that is with taking rear wheel off, and install the rear in parts it is a lot easier.
Had an '01 FXDXT with Sputhe mounts, aluminum swingarm, alloy rims and composite rotors. Bike felt like it had power steering (and brakes) compared to a stock Dyna.
'06 and later are even heavier, but have a stiffer front fork with the newer 49mm tubes. I've found setting fall-away just an extra 1/8 turn tighter helps a lot, too. I would try that before installing a steering stabalizer...
I currently ride a Fat Bob, tightening the fall away and better tires are all I've done so far to the chassis. The engine has been modded for more torque
Stability and handling can be improved, but you will still have your butt handed to you by a 600 sport bike
Not only steering preload and mount condition but rear wheel alignment with the rest if the frame.. The front mount (IMO) is more important than the rear on Dynas without saddlebags. Add a bunch of weight down low in the back and you'll need the rear just like on the baggers. What I find interesting was when I first tried the Sputhe it really didn't make much difference. I have a 2000 FXDX so for 1, the suspension is already pretty good.. Bike has a 116 ci motor that makes/made about 125 hp / 130 tq.. It had a habit of dancing when rolling the throttle on in 4th especially after the rear tire (150/80-16 Metzler) was over about 1/2 worn. New tires were OK. Adding the Sputhe did nothing for the handling except to increase the frequency of the dance.
The motor had issues with valve guides and on inspection the crank was starting to spread so I rebuilt the motor, replaced the sheet metal with fresh paint and fit a rear wheel that would hold 180/55-18 rear tire.. I did do some realigning of things in the process. Rear tire brought to center, vertical alignment adjusted some.
After the mods, the bike is one of the best tracking I've ever ridden. 0 wobbles. With or without the rear Sputhe, I see no change. Front the is a slight difference but it's mainly in the choppy corners. I'm not saying that the Sputhe is no good. There are too many here that say it works for them and it's a good place to start for sure but it may not be the complete cure for some..
Back to the OP. Not only would I buy the sputhe but I'd also add emulators to the front or one the the better cartridges for inner parts and better shocks to the back. If running spoked steel rims, replace with mags or alloy hoops. If you have a single disk up front, go to 2.
"90-100mph"? Leaned over, that's sport bike territory. You'll need to do mods on a cruiser if you want stability at those speeds. Headshake can be a bad thing, as the CHP is finding out with their baggers.
That's just keeping up with traffic early Sunday morning in the 405 carpool lanes, just like dancin' with a fat girl...
While I do not ride like on a racetrack, installed the predator earlier this year, for about 250 bucks, is a great improvement. did not notice change in vibration, but can for sure notice better stability when in ruts or grooves.
Yep agree totally, it is really quite simple the older the rubber mounts get, or even a little oil on them that makes them softer, the wobble will come, and for gods sake if you aint got 3 stabilisers, or a minimum of 2, please do not put your life at risk at these speeds, because if it really gets the death wobble, well it was not worth us trying to explain, it will be too late, and also agree with a post about the Predator, it is a well built stabiliser with motor mount built in, I followed it from day 1, but just prefered traditional stabilisers, but that is only a preference on my side, you will see a good improvement with just the front, because in theory your Dyna will be like an FXR with 2 stabilisers, but just a diffferent frame.
Yeah, I can't imagine a steering damper on the street. The mannerisms of my Scott's that I have on my WR make me cringe when I think of it being on my Harley. Around town, I think it would suck. Adjusting the Scott's on the fly is easy enough
