Gauge swapping on the FXDL-S
Old Dec 16, 2016 | 06:51 AM
HotRodNut's Avatar
HotRodNut
Default Gauge swapping on the FXDL-S
After riding my Low Rider S for a short while I see I am more interested in seeing the RPMs vs the Speed. Is it possible to swap positions of the gauges so the Tachometer is up front?
Old Dec 16, 2016 | 09:21 AM
lowboy72's Avatar
lowboy72
I tried, actually my very first mod attempt. The cup mounting depth is different and you cannot swap.
Old Dec 16, 2016 | 09:34 AM
HotRodNut's Avatar
HotRodNut
Kinda figured, I appreciate your reply, saved me some time tearing into to find out for myself.
Old Dec 16, 2016 | 09:40 AM
cvaria's Avatar
cvaria
no no... you just need to make adjustments and actually modify. "Can't", "cannot", and "can not" are not acceptable. There's doing, and then there's not doing.
Fun times.
Old Dec 16, 2016 | 10:17 AM
lowboy72's Avatar
lowboy72
Fun times.
Can't here is simply that the stock configuration "can't" support the modification without additional labor or cost. I am open to any suggestions you might have otherwise for a way to do this without significant effort.
Old Dec 16, 2016 | 10:24 AM
cvaria's Avatar
cvaria
space the gauges with spacers and sleeve on the speedo since it "may" sit a little higher in the rear slot.
[may have an issue with the wire lengths, may not]
or.... get moused
https://www.hdforums.com/forum/dyna-...-quetions.html
tonixen
2018+ Softail Models
Jul 13, 2019 02:50 PM
Pinoy_gm808
May 7, 2017 10:44 PM
JDavis187
May 14, 2013 01:54 PM
kopchas
General Topics/Tech Tips
May 27, 2010 12:17 PM
Balsam41
Sep 21, 2008 10:47 AM
