Squirrely rear
Old Dec 21, 2016 | 06:33 AM
wideglideCVO's Avatar
wideglideCVO
Old Dec 21, 2016 | 07:49 AM
TinCupChalice's Avatar
TinCupChalice
cvaria, exactly where are your tire pressures? With their more rounded profile the Pirelli Night Dragons are sensitive to their pressures. I've experimented with different tire pressures and found there is a definite change in handling if the pressures are too low or too high.
When the rear was too low on my 180/60-17 Night Dragons the rear did feel a bit squirrely; I found 43 - 44 PSI was the sweet spot. That may give you a good starting point for your 180/55-18.
The front is the same, don't run them too low; the handling goes out the window and tire wear increases rapidly. With my 90/90-21 Night Dragon 40 PSI was the spot. Even a 2 PSI change lower was enough to be noticeable.
If all was well beforehand and the only change you made was to your tire PSI you know right where to start looking
Old Dec 21, 2016 | 08:17 AM
NorthWestern's Avatar
NorthWestern
Get a second opinion with a new tire pressure gauge. Seen this more than once
Old Dec 21, 2016 | 08:24 AM
NC Rob's Avatar
NC Rob
I will be in the market for new tires soon and I was going to pick up Night Dragons but now I am having second thoughts if they are that sensitive. What if you go for a ride and one loses a little pressure? Bike rides like crap and potentially dangerous until you can get to somewhere you can fill it? Not trying to be a smart ***, really asking you guys that own them and have a lot more experience then I do.
Old Dec 21, 2016 | 08:38 AM
cvaria's Avatar
cvaria
I'm at 40r/38f i will try 44r/40f.
i think the cold weather mayhave had a hand in this.
@other questions:
the bearings are new (sketchy hd full metal bearings 9276b), wheels new and are cast, tires are new. ... but my hands touched them all so... they could all be fubar, lol
Old Dec 21, 2016 | 08:40 AM
NorthWestern
Whooaaa there The Night Dragons are solid, and I have pushed mine hard. They are no more sensitive to pressure loss than any other tire. The profile difference just lends itself to a bit more planted feeling in the corners than the typical tire found on a stock Harley. You will not be disappointed.
Old Dec 21, 2016 | 08:46 AM
cggorman's Avatar
cggorman
@other questions:
You have too low an opinion of your work!
Old Dec 21, 2016 | 08:50 AM
cvaria's Avatar
cvaria
no no. This is random. Night dragons are probably the best performance street tire for these heavy cruisers. It's probably just me hamfisting something because they were fine before i fooled with the pressures.
Ive been running NDs for about a year and would have put them on my sporty if it weren't for the radial/bias ply nonsense restricting me from doing the 150/70/18 & 120/70/19 pairing. Only to find out that someone else had done it. Waiting to see how long he goes with his ND Bias Rear/ Radial front before he says something. The gt502s are trash and i dont want them on my bike. I feel safer with night dragons.
Old Dec 21, 2016 | 08:55 AM
cvaria's Avatar
cvaria
Im a one man demo crew. Hulk smash
Old Dec 21, 2016 | 09:11 AM
cggorman's Avatar
cggorman
Keep Smashing it up, then, cause from what I can see you're doing a lot of good work!
