Squirrely rear
Old Dec 20, 2016 | 02:33 PM
cvaria's Avatar
cvaria
Default Squirrely rear
My rear tire suddenly became squirrely. Not sure why. I haven't lifted the bike to shake the rear wheel because my sporty has been on my fear lift but, everything looks okay.
by squirrely, i mean that the rear feels like it is ready to shoot out in either direction at any given moment. Last change i made was adjusting the air pressure. Does that seem like something that would cause a wacky rear tire? There were two cheek puckering moments over the past weekend were the rear suddenly shifted left.. this was at low speed.~40mph.
ideas?
Old Dec 20, 2016 | 02:57 PM
cggorman's Avatar
cggorman
I doubt this is it, but axle and adjusters are tight?
Old Dec 20, 2016 | 03:07 PM
cvaria's Avatar
cvaria
seems that way but, i will re-torque the to be sure.
Old Dec 20, 2016 | 03:08 PM
F86's Avatar
F86
If you adjusted the pressure up, I would doubt it (unless it was a BIG adjustment!)... Some kinds of tires really need more pressure than OEM though, so if it was a downward adjustment... I dunno. Still seems unlikely.
Rear wheel alignment? Adjusters? Did you do anything that could affect rear wheel vertical alignment? When I got mine right, the rear definitely felt better...
Front or rear motor mount? If the motors moving too much, so is the swingarm...
These issues are maddening... There are so many variables at play in a Dyna chassis!
cggorman's Avatar
cggorman
Were you ever into the front engine mount/isolator? ie, Any reason to suspect it may be loose/worn?
Old Dec 20, 2016 | 03:13 PM
cggorman's Avatar
cggorman
Just because SOMEBODY had to...
Old Dec 20, 2016 | 03:17 PM
cvaria's Avatar
cvaria
she looks like a pedophile.
Old Dec 20, 2016 | 03:20 PM
cvaria's Avatar
cvaria
only time i messed with the front mount was the oil cooler install. I can retorque those bolts too. If nothing seems really off. I may have to had this job off. Wild rear tire is bad business. I just about threw up when it happed the first time.
Old Dec 20, 2016 | 03:32 PM
cggorman's Avatar
cggorman
I can imagine. Might as well check the upper motor mount/stabilizer as well. I would expect to hear that rattling if it was loose, though.
Did this happen under decel, braking (F or R?), accel, cruise, etc.?
Old Dec 20, 2016 | 03:35 PM
NC Rob's Avatar
NC Rob
I would like to check her squirrely rear.
