Squirrely rear
Old Dec 23, 2016 | 02:06 PM
  #41
TinCupChalice's Avatar
TinCupChalice
Glad you got it!
Old Dec 24, 2016 | 01:17 AM
  #42
NorthWestern's Avatar
NorthWestern
Originally Posted by cvaria
it was the tire pressure. ran at 44r/40f and there was no squirrelnicity. Wincup wins again
Right on. I am running 42/42 FWIW, and they have been great.
Old Dec 24, 2016 | 05:51 AM
  #43
buck23568's Avatar
buck23568
2nd Gear
Default process of elimination
Start at the rear wheel ie run a screwdriver around the spoke listening for any change in pitch, if ok check ur wheel bearings although if one of them has **** itself u will also have more than normal free travel in ur rear brake pedal, the rear shock bushes[highly unlikey] then rear motor mount , swing arm bushes But ofcourse check the easy stuff first ie tyre pressures , condition and so on , good luck
Old Dec 24, 2016 | 06:07 AM
  #44
Notgrownup's Avatar
Notgrownup
Seems like every tire has a sweet spot fir pressure and then the persons weight enters the equation....glad you figured out your combo
strtarrow
Aug 12, 2020 12:57 PM
Nokkon Wud
Wheels/Tires
43
Nov 15, 2017 10:13 PM
ReidRik_Von
Nov 12, 2017 10:30 AM
dawg
Aug 23, 2011 05:28 AM
hawkeye85
Apr 17, 2010 07:40 AM
